jbrnr21 Silver Donating Members 120 Member For: 12y 2m 27d Gender: Male Location: bathurst... Posted 04/08/12 11:52 PM Share Posted 04/08/12 11:52 PM Ok with this changeover relay... The accessories wire that goes to the relay, do I just tap into it an still have it connected to the accessory wire aswell or do I cut it off and hook it up from the timer straight to the relay? Link to comment Share on other sites More sharing options...
foxtrot Member 77 Member For: 15y 11m 20d Posted 18/08/12 10:39 AM Share Posted 18/08/12 10:39 AM Hi. Do not connect the accessories wire from the turbo timer to accessories, you only use it to make the relay switch. If you want to sit in the car and listen to the radio you dont need to use the turbo timer. Cheers MD Link to comment Share on other sites More sharing options...
jiri styles Member 8 Member For: 12y 8m 11d Posted 05/05/18 03:49 AM Share Posted 05/05/18 03:49 AM I installed my turbo timer exactly liek you did, but my turbo timer jsut shut off when the car shuts off, I think its a turbo timer issue not a wiring issue , the turbo timer is a hks type 0 copy.. Link to comment Share on other sites More sharing options...
foxtrot Member 77 Member For: 15y 11m 20d Posted 28/08/18 10:10 PM Share Posted 28/08/18 10:10 PM On 5/5/2018 at 1:49 PM, jiri styles said: I installed my turbo timer exactly liek you did, but my turbo timer jsut shut off when the car shuts off, I think its a turbo timer issue not a wiring issue , the turbo timer is a hks type 0 copy.. Hi. Make sure that the yellow power wire is a constant feed, not the Acc feed. Cheers MD Link to comment Share on other sites More sharing options...
