BIGGUNS Member 15 Member For: 16y 7d Posted 17/07/09 10:16 AM Share Posted 17/07/09 10:16 AM Hi guys, turned a corner and put the foot down with the traction control on and the beast just started missing like when you lose it on a corner and the engine cuts out with the traction control on. Kept driving and it does it just when you put the oot down. Also has a turbo flutter which wasn't there before ( probably because its not using the boost ). Stopped and turned the car off but still doing it. Read on other post it maybe the plugs or but this is something that definatelty went bad straight away. Anyone had this problem and had it fixed before?? Wanna try to get it done on the weekend,... Link to comment Share on other sites More sharing options...
sleeper69 Member 179 Member For: 18y 6m 21d Gender: Male Location: melbourne Posted 17/07/09 10:25 AM Share Posted 17/07/09 10:25 AM (edited) could be an air leak somewhere, check one of your hoses hasn't come off Edited 17/07/09 10:25 AM by sleeper69 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 11m 20d Gender: Male Location: Probably above atmospheric pressure Posted 18/07/09 07:44 AM Share Posted 18/07/09 07:44 AM My car is pretty much flawless...except turning a corner and giving it a mild hit of throttle about a month ago. It just didn't go...got all quiet, I thought it might have been fuel swaying away from the pickup since I flung around the corner, not moving fast, but sharp turn-in.Fuel was above half for sure. Didn't notice my TC light go on either. Only done it the once here! Link to comment Share on other sites More sharing options...
BIGGUNS Member 15 Member For: 16y 7d Posted 19/07/09 08:00 AM Author Share Posted 19/07/09 08:00 AM Hey changed the sparks plugs and it fixed the problem - she's back to pullin like a school boy. Thanks Mike for you step be step guide made it easy as. Link to comment Share on other sites More sharing options...
