  • Member For: 17y 6m 22d
Poor Bugger, sound's like you have been through hell with the build but im sure in the end you will be more than happy with it...
Race fuel tune is not worth worrying about unless you plan on racing often, I would be more focused on getting as much as I can on pump and possibly an E85 tune aswell...
Im very interested to see the outcome you achieve, as I have nearly exact same combination, only difference being mine's an Atomic 998GTR and ive gone larger turbocharger (GT47-88) so im keen on seeing your final result's both on pump fuel and race fuel, im most likely going to have mine tuned for straight E85 seeing's as Caltex are releasing it this month and the servo is less than a kilometer away and another is about 5 kilometer's away so it's nice and close...
Im only fitting it into my Falcon for awhile over the Xmas period until my other car is done then im swapping it into that, that car is going to be atleast 1000lb lighter than the Falcon so it should be interesting ride...
Goodluck with it all...
  • Replies 354
  • Legendary member!!
  • Member For: 18y 4m 5d
Whats the difference between the 998 and 998 GTR Atomic motors JET??
  • Member For: 18y 2d
  On 09/09/2010 at 4:20 AM, HIRO F6 said:
First update is they are at 510hp at 10psi!!!
  • Member For: 16y 4m 8d
Final power figure is around 450 - 470rwkw's at 20psi.
Due to the diff gears the car is maxing out 4th gear at around 190km/h. Hi Torque said this car was throwing ruber at the rear wall of the dyno cell.
I'll let Matt elaborate more when he jumps on but I believe he's off to the drags on saturday night with a set of MT's to see what the mph is on this car to get a better idea of its true power levels.
Here you go mate here's the list of both engine's off Atomic's site to read for yourself...
998GT-A....Part No :306492 998 long, BA Ford DOHC $13,750.00 998 GT-A
MY2010 Atomic 998GT-A Long engine specs
• Ultrasonic tested block in 4 spots per cylinder – thick walls are required (we reject 4 in 10 for being like Cleveland blocks - too thin in spots due to core shift)
• Full Race Spec crankshaft preparation - magnafluxed, checked for index/stroke, 3 stage Heat treatment (normalise, stress relieve and gas nitride), lightened counterweights, cross drilled main journals, reground, indexed, micropolished journals and chamfered oil holes.
• Cosworth F1 Series pistons – 8.5: comp ratio and include coated skirts, anti detonation bands, polished crowns, H/D pins and piston crown cooling - an Atomic exclusive. Totally silent operation.
• Cosworth nitro carburised steel turbo rings
• Atomic billet FatRods #306201 - bushed for floating pins, ARP2000 bolts, cylindrically ground/honed tunnels and pressure fed gudgeon pins – an Atomic exclusive.
• ACL Competition bearings with extra oil feeds for little end bushes
• Fully machined block inc torque plate honed cylinders, decked to crank centreline, main saddle alignment checked etc
• Race spec clearances to suit the intended usage
• Fully prepped Stage 4 cylinder head with 5-angle CNC machined valve job and porting of both inlet and exhaust. Fine Ra finish on deck surface, chambers relieved and CC’d, spring tensions set up and new PC seals fitted.
• Atomic Hi-Rev anti pump up lifters fitted and lifter preloads set.
• Atomic H/Duty Simplex timing chain
• Atomic Induction hardened crank sprocket
• Atomic Hi pressure timing chain tensioner
• Precision balanced
• Atomic Hi-Mass ANDRA/SFI approved harmonic balancer
• Atomic Race Spec NASCAR valve springs - good for 34+lbs boost
• Titanium valvespring retainers
• Atomic Head stud kit - 12mm
• Atomic Billet gear oil pump – complete with EDM cut chrome moly gears, billet end plate (hard anodized), Grade 10 fasteners, high flow bypass circuitry and blueprinted clearances.
• Atomic Duo-phased cams – your choice of profiles
• Atomic gasket set inc SLS Teflon coated head gasket and Viton crank seals
• Fit new brass welch plugs
• Atomic main cap support girdle and windage tray
• Spray block grey (or any other colour you prefer)
• Precision blueprinting and assembly of long motor
• Engine is fully test run in our engine test cell - verify all vitals of the engine (oil pressure hot and cold, ring bed-in, cylinder % leak down, lifters bled, etc) and report supplied.
• Supply detailed specs report of engine and run-in procedure sheet
• Supply 8 litres of Castrol ProTec run-in oil
• Supply genuine Ford oil filter
• 24 months warranty
998GT-R....Part No:306496 998 GT-R long, BA-BF $18,997.00 998 GT-R
MY2010 Atomic 998GT-R Long engine specs
• Deck surface CNC machined to accept 14.3mm Atomic head studs
• O-ringed block to suit copper head gasket
• O-ringed cylinder head to suit copper head gasket
• Oversize ID head dowels
• Fully prepped Stage 5 cylinder head with 5-angle CNC machined valve job and porting of both inlet and exhaust. Fine Ra finish on deck surface, chambers relieved and CC’d, spring tensions set up, oversized head bolt holes and new PC seals fitted.
• Inconel super alloy exhaust valves
• Atomic Vernier adjustable Camshaft sprockets
• Atomic Head stud kit - 14.3mm
• Atomic gasket set inc Copper head gasket and Viton crank seals
• 3 months warranty
The 998 is optioned up with the addition of our famous FatRods, CNC machining of the block for our whopping 14.3mm head studs, copper head gasket, dual stainless O-rings per cylinder, lightened and heat treated crank, different bearing clearances, a main cap support girdles and a set of our Race Series valve springs to cope with high boost levels.
Feel free to mark out the difference's you can see between the if you or anybody else like's...
Edited by JETFPV
