Worlds Quickest Fg!
The_Bogan
  • Member For: 17y 10m 5d
was out at willowbank last night piloting our FG F6.
managed to run a new PB and reset the record to 11.08@124mph with a 1.6 60ft.
the nizpro cooler seemed to do to the trick!!!
I will post up the time slip details when I see paul later on.
and I do believe that there is definately a 10 in her!!
because the 6 speed auto's are a different animal compared to the 4speed that im used to.
every shift has to be perfect, 1 little stuff up on where I shifted and it ruined the run!
  • Replies 52
  • Member For: 16y 9m 26d
this is crazy so the only mods are a nizpro exhaust avail over the counter , injectors (what type??) and a nizpro cooler once again over the counter and a tune 10s for sure coming good work guys :beerchug:
here are the details of the run.
60ft:1.620 330ft:4.662 660ft:7.150 MPH:99.21 KPH:159.66 1000ft:9.274 ET:11.085 MPH:124.72 KPH: 200.72
11 deg. 61%H, 1012mB, -168RA, (TT) 20 deg
Edited by The_Bogan
  • Member For: 17y
that's an awesome result for such minimal mods, 1.6 6o' is impressive. There must be some thing special in the 'Elite enhanced' injectors.
Was that full wait and pump fuel?
Can you post up a dyno sheet ...
Do you care to share some of your launch technique for the ZF......
Edited by jimmy1234
  • Member For: 18y 5m 8d
Elite injectors are high flowed to our specs.
Weight of car was 1802 kg.
Fuel was Shell vpower 98 no additives.
Jim at tunehouse knows the launch tune technique as all NPIA members.
I will get Boges to post up a dyno charts.
Cheers Paul
