Ba Xt And Xr6t Tail Shafts
n1ck
  • Member For: 16y 4m 23d
need a little info did a search found nothing
just wondering if anyone knows if the tail shaft in a ba xt will bolt upto a xr6t diff
I know the drive shafts are differant just not to sure on the tail shaft
any help will be great
regards Nick
  • New Member
  • Member For: 16y 3m 11d
Xt and Xr6t tailshafts are different and cant be swapped, the rubber drive coupling at both ends of the tailshaft diff and gearbox ends is larger in diameter (pcd) and wont bolt up. The tailshaft has three legs at each end that bolt to the rubber coupling these legs are also larger in diameter (pcd).
  • Here since the start...
  • Member For: 21y 9m
Well as posted above the ends of the tailshaft are bigger so I'm sure the diff pinion yoke is bigger.
