hazaturbo Member 56 Member For: 15y 11m 28d Gender: Male Location: Revesby Posted 08/07/09 03:00 PM Share Posted 08/07/09 03:00 PM If you had about $6000 to spend on mods, what would you spend it on? Looking for over 300kw at the wheels. Link to comment Share on other sites More sharing options...
NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 17y 20d Gender: Male Location: Perth, WA Posted 08/07/09 03:31 PM Share Posted 08/07/09 03:31 PM Mate,$6K will get to closer to 350rwkw I'd say.You will probably want to go for;60lb Dekkas - ~$500 Installed (RA1D has some for $399 atm)Fuel Pump - ~$200RAP1D, Plazmaman, PW I/C and Piping Kit - ~$2K for a good one - Maybe a V3? One was for sale for $1300 recently.Custom Tune and Flash Box - ~$1500X-Force Turbo Back system - ~$2KThat's about $6K supplied and installed. This should give you 320+rwkw on about 12-14psi? Probably even more. May also want to look at a surge tank, or flapper mods as well.Do you want to upgrade Brakes or Suspension? You could get some DBA 4000 slotted rotors and some whiteline sway bars as well if you wanted to go that way. A brake upgrade is a pretty good idea with 300rwkw+Hope that helps mate,Dan Link to comment Share on other sites More sharing options...
Brandonn Donating Members 2,304 Member For: 16y 5m 9d Gender: Male Location: port hedland Posted 08/07/09 04:27 PM Share Posted 08/07/09 04:27 PM my 2 bob (similar to nvt's)-Xcal 3 and custom tunes $1500-siemens 60lb injectors $500-rapid v2 intercooler kit $1500-fuel pump $200-exforce exhaust (on ebay brand new) $1600 -Labour $700TOTAL $6klol that's about as gud as I can think upyour next step would definatly be valve springs about 800 fitted Link to comment Share on other sites More sharing options...
Brandonn Donating Members 2,304 Member For: 16y 5m 9d Gender: Male Location: port hedland Posted 08/07/09 04:28 PM Share Posted 08/07/09 04:28 PM n that would get u your 300 easy but wih valve springs ud get into about 330 Link to comment Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 21y 4m 22d Gender: Male Location: Sydney Posted 08/07/09 11:25 PM Share Posted 08/07/09 11:25 PM Bilsteins, Kings 520/310, 27/22mm sway Bars, alignment $1800DBA 4000 Rotors, Fluid, SS Lines, DS2000 Pads $1000HP Tuners Custom Tune + Injectors + fuel pump + cat $1650-1900Rapid STG1, UBP $1200?300rwkw with stopping and handlingaddress the brakes and suspension unless you want a flying waterbed Link to comment Share on other sites More sharing options...
hazaturbo Member 56 Member For: 15y 11m 28d Gender: Male Location: Revesby Posted 09/07/09 12:08 AM Author Share Posted 09/07/09 12:08 AM Thanks for the info guys. Will look into it. Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 2m 25d Gender: Male Location: Melbourne Posted 09/07/09 01:07 AM Share Posted 09/07/09 01:07 AM Nizpro stage 2+ Link to comment Share on other sites More sharing options...
wiresquire Member 266 Member For: 20y 2m 30d Posted 09/07/09 02:40 AM Share Posted 09/07/09 02:40 AM (edited) Stage 2+ is RRP $3.4K and requires the Stage 2 which is RRP of 8K.Did I miss something or did you mean Stage 1+?ws Edited 09/07/09 02:41 AM by wiresquire Link to comment Share on other sites More sharing options...
