Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 5m 5d Gender: Male Location: Perth Posted 09/07/09 10:10 AM Share Posted 09/07/09 10:10 AM I bet the 'sealing face' isnt quite square no joke.one of the Perth turbo e-series guys had this same issue with their Snort plenum,another had issues with the threads for the bolt holes,I had issues with the threads on the vacuum lines. Link to comment https://www.fordxr6turbo.com/forum/topic/59359-motor-not-running-after-plenum-change/page/4/#findComment-903951 Share on other sites More sharing options...
FPV_Steve Donating Members 191 Member For: 17y 11m 8d Gender: Male Location: Brisbane Posted 09/07/09 10:29 AM Author Share Posted 09/07/09 10:29 AM Na didnt get it sorted man. Got it to run but had to keep revs up til it got warm. Took it for test drive and still did the same when idled at lights. Heard a high pitched squeal after boost (when bov went off) sounded like it was near the plenum. What difference would it make if the boost sensor was on the plenum (after throttle body) instead of infront of throttle body. Was in front of throttle body before. Link to comment https://www.fordxr6turbo.com/forum/topic/59359-motor-not-running-after-plenum-change/page/4/#findComment-903965 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 1m 17d Gender: Male Location: syd south Posted 09/07/09 10:46 AM Share Posted 09/07/09 10:46 AM FPV_Steve said: What difference would it make if the boost sensor was on the plenum (after throttle body) instead of infront of throttle body. Was in front of throttle body before.Your kidding right? Link to comment https://www.fordxr6turbo.com/forum/topic/59359-motor-not-running-after-plenum-change/page/4/#findComment-903990 Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 16y 11m 7d Gender: Male Location: sunshine coast Posted 09/07/09 10:49 AM Share Posted 09/07/09 10:49 AM shouldnt it be before the throttle body? Link to comment https://www.fordxr6turbo.com/forum/topic/59359-motor-not-running-after-plenum-change/page/4/#findComment-903993 Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 16y 11m 7d Gender: Male Location: sunshine coast Posted 09/07/09 10:51 AM Share Posted 09/07/09 10:51 AM got any pics steve? Link to comment https://www.fordxr6turbo.com/forum/topic/59359-motor-not-running-after-plenum-change/page/4/#findComment-903997 Share on other sites More sharing options...
FPV_Steve Donating Members 191 Member For: 17y 11m 8d Gender: Male Location: Brisbane Posted 09/07/09 10:51 AM Author Share Posted 09/07/09 10:51 AM No Im not mate. When I got my rapid v3 setup the boost sensor on the drivers side needed a hose running over to the cold pipe before the throttle body. Now I have a plazmaman pipe from under headlight to t/b and it only has provision for a BOV. So I ran boost sensor hose to unde plenum. Was told this will be ok?? Link to comment https://www.fordxr6turbo.com/forum/topic/59359-motor-not-running-after-plenum-change/page/4/#findComment-904000 Share on other sites More sharing options...
FPV_Steve Donating Members 191 Member For: 17y 11m 8d Gender: Male Location: Brisbane Posted 09/07/09 11:09 AM Author Share Posted 09/07/09 11:09 AM turbo.vixen said: shouldnt it be before the throttle body? Ok that's what I thought. It will be reading vacume instead of boost right? It will be getting the same info as the map sensor! f*ck me, that will be my problem. I will tap a 3/8 fitting into the cold side pipe tomorrow and hook her up and let you know what it does. What a nightmare!!!!!!!!! Link to comment https://www.fordxr6turbo.com/forum/topic/59359-motor-not-running-after-plenum-change/page/4/#findComment-904021 Share on other sites More sharing options...
Locomick AK47's for everybody Donating Members 131 Member For: 19y 1m 22d Gender: Male Location: somewere Posted 09/07/09 11:11 AM Share Posted 09/07/09 11:11 AM mate there are 2 boost sensors, 1 in the intake plenum and 1 b4 the tb on the cold side pipe. if u put that one on the plenum aswell the ecu go's wtf is going on lolcheers mick Link to comment https://www.fordxr6turbo.com/forum/topic/59359-motor-not-running-after-plenum-change/page/4/#findComment-904023 Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 16y 11m 7d Gender: Male Location: sunshine coast Posted 09/07/09 11:13 AM Share Posted 09/07/09 11:13 AM no the one in the plenum is a map sensorand steve your right it will be reading the same as the map sensor lol, that will be your problem Link to comment https://www.fordxr6turbo.com/forum/topic/59359-motor-not-running-after-plenum-change/page/4/#findComment-904027 Share on other sites More sharing options...
FPV_Steve Donating Members 191 Member For: 17y 11m 8d Gender: Male Location: Brisbane Posted 09/07/09 11:13 AM Author Share Posted 09/07/09 11:13 AM Locomick said: mate there are 2 boost sensors, 1 in the intake plenum and 1 b4 the tb on the cold side pipe. if u put that one on the plenum aswell the ecu go's wtf is going on lolcheers mickThanks Mick. The one on the plenum is the map sensor right? Link to comment https://www.fordxr6turbo.com/forum/topic/59359-motor-not-running-after-plenum-change/page/4/#findComment-904028 Share on other sites More sharing options...
