kirjo Member 113 Member For: 16y 15d Gender: Male Location: Brisbane Posted 01/11/09 10:58 AM Share Posted 01/11/09 10:58 AM Another question- what is going on with the AFR's during these runs? Link to comment https://www.fordxr6turbo.com/forum/topic/59178-power-differences-between-shootout-modes/page/4/#findComment-949488 Share on other sites More sharing options...
The_Bogan Donating Members 881 Member For: 18y 2m 27d Gender: Male Location: Brisbane, Queensland Posted 12/11/09 08:56 AM Author Share Posted 12/11/09 08:56 AM What would the difference in power be if the air temp was 31c and intake 27c.Will the warmer conditions cause ecu to take out timing,lean out.If I was doing 375rwkw on a 31c day,would it show more on 20c day.I was told that the dyno shows more on a warmer day.What power difference would your shoot 6f show if you run your car on a warm day say 30c.I noticed it was run on a very cold day.if the intake temp was showing lower than the ambient temperature then you would be showing a bee's dick less power. though this is within the limit of around 5-10 deg either way.to get an accurate power figure the ambient temp and intake temp should be identical.and no, the only reason your computer would take timing out on a warmer day would be due to the fact that your intake temps have risen and your car is pining, and your ecu has taken timing out when it sensed detonation occuring.on a warmer day, your car will run pretty close to whatever it was tuned to on the first run, then drop considerably on the 2nd run due to intake temps climbing.a dyno will not show more on a warmer day, quite the opposite, the cooler the air going into your car, the more power it is going to make. hence the reason for bigger intercoolers.yes, these runs were done between 8:30am I believe and I think I wrapped up at around 11am from memory.and I believe this was done in the cooler months.if it was run on a cold day, then run on a warmer day, I would guesstimate around a 10rwkw difference, quite possibly more. but during that time between the cooler weather and warmer, turbo or manifold bolts may have come loose and thrown both runs out if you really wanted to see the difference.and to those nay sayers commenting on my afr's, I couldnt give a rats arse.my car doesnt/has never detonated on the road. the only time it has detonated is during tuning.and at the time I did these runs on the dyno, my car hadnt been touched tune wise for at least a year.not to mention the cooler weather causing the car to run a little bit more boost, and hey presto, leaning it out somewhat. but not to a degree where I was worried about stopping the dyno run halfway. Link to comment https://www.fordxr6turbo.com/forum/topic/59178-power-differences-between-shootout-modes/page/4/#findComment-953222 Share on other sites More sharing options...
berzerker Donating Members 767 Member For: 17y 6m 10d Gender: Male Location: Brisbane Posted 12/11/09 10:08 AM Share Posted 12/11/09 10:08 AM BOGAN: have you got all your latest bits put on the car yet? Havent heard much for a while.. Link to comment https://www.fordxr6turbo.com/forum/topic/59178-power-differences-between-shootout-modes/page/4/#findComment-953258 Share on other sites More sharing options...
Guest Al@n Guests Posted 12/11/09 10:55 AM Share Posted 12/11/09 10:55 AM As a new member I find this very interesting. Karl Marx would put this down to capitalism, the more you spend the more you make, absolutely fascinating results. although my intrepretive skills may be lacking, has any one seen what I have, Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/59178-power-differences-between-shootout-modes/page/4/#findComment-953280 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 6d Gender: Male Location: Brisbane Posted 13/11/09 01:35 AM Share Posted 13/11/09 01:35 AM Link to comment https://www.fordxr6turbo.com/forum/topic/59178-power-differences-between-shootout-modes/page/4/#findComment-953436 Share on other sites More sharing options...
GR8XR6 ANGEL EYES Silver Donating Members 1,683 Member For: 16y 11m 9d Gender: Male Location: SE Suburbs, Melbourne Posted 13/11/09 05:17 AM Share Posted 13/11/09 05:17 AM Link to comment https://www.fordxr6turbo.com/forum/topic/59178-power-differences-between-shootout-modes/page/4/#findComment-953481 Share on other sites More sharing options...
SPIKO Gold Donating Members 1,924 Member For: 20y 2m 24d Gender: Male Posted 04/12/09 07:10 AM Share Posted 04/12/09 07:10 AM This is the very reason why C&V & 6Boost have been tuning without the temp probe and not in shoot mode for years!!!I have tried personally to explain this to poeple for a very long time, no one listens!!!Glad to see this test done, well done Bogan! Link to comment https://www.fordxr6turbo.com/forum/topic/59178-power-differences-between-shootout-modes/page/4/#findComment-960281 Share on other sites More sharing options...
The_Bogan Donating Members 881 Member For: 18y 2m 27d Gender: Male Location: Brisbane, Queensland Posted 04/12/09 08:38 AM Author Share Posted 04/12/09 08:38 AM not having a go at you spiko...the temp probe does play a pretty big part in how the dyno dynamics dyno calculates power and what power will come up onto the screen though.if the temp is less than the ambient temp, then it is going to show a sh*tload less power.I have personally had this happen to me at a dyno day I was at recently in our vy ss.the intake temp was at -28 degress celsius, end result 294rwp.I pulled them up about it and they were kind enough to throw it back on with the intake and ambient temps even.next power run ended up at 344rwhp I think....though if you have the intake temp higher its going to show more.im over power figures on a dyno, they look good for around 5 minutes....get it out to the drag strip and see how quick it is and the mph.... that's the true indication. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/59178-power-differences-between-shootout-modes/page/4/#findComment-960302 Share on other sites More sharing options...
SPIKO Gold Donating Members 1,924 Member For: 20y 2m 24d Gender: Male Posted 04/12/09 08:49 AM Share Posted 04/12/09 08:49 AM It always was and always will be a tuning tool, I agree with what you are saying in part, however I have seen many a dyno figures manipulated with temperature in my time. If the overall figure itself doesn't matter then who care's if it is showing lower without the temp probe? This is the point I have been trying to make. As long as the same dyno/Mode without temp, is being used for all tune's and cars and comparative level can be achieved.This is only my humble point of view anyways! Link to comment https://www.fordxr6turbo.com/forum/topic/59178-power-differences-between-shootout-modes/page/4/#findComment-960306 Share on other sites More sharing options...
The_Bogan Donating Members 881 Member For: 18y 2m 27d Gender: Male Location: Brisbane, Queensland Posted 04/12/09 08:56 AM Author Share Posted 04/12/09 08:56 AM (edited) I agree with that!!!but some people like to see numbers!!!im over chasing a number on a screen now!on our dyno my car makes considerably less to the next workshops.my best run ever on a dyno was 345rwkw. and it wasnt ours..which, considering the mph I run at the drags, is a good indication of the power im actually producing.the day before I made 345rwkw on another workshops dyno my car made 313rwkw on our dyno.... I couldnt care less.... it does 11.0's @ 124mph.all that matters now is the 5 numbers at the bottom of the timeslip at the tower at willowbank!!! Edited 04/12/09 08:59 AM by The_Bogan Link to comment https://www.fordxr6turbo.com/forum/topic/59178-power-differences-between-shootout-modes/page/4/#findComment-960309 Share on other sites More sharing options...
