Autometer Oil Pressure Gauge
Hendrik
  • Member For: 15y 9m 12d
when I baught my BF XR6T it came with an Autometer Cobalt Boost/Vaccume and oil pressure gauges fitted. the boost gauge works fine, however the oil pressure gauge doesnt seem to be working at all. it just sits inbetween 25 and 50 psi and doesnt move even when the car is switched off. any suggestions?
this is the particular gauge
http://www.egauges.com/vdo_ind.asp?Type=El...amp;PN=ATM-6127
cheers hendrik
  • Member For: 16y 8m 13d
What Are These Colored Wires On My Electric Pressure Gauge For?
Red = key on power supply
Black = common chassis ground
White (Cobalt, C2, Lunar, & NV series only) = dash lighting power
Gray, Purple, & Black = communication between sender and gauge
  • <put funny sh*t here>
  • Member For: 18y 3m 25d
the power for the backlight is seperate to the power going to the oil pressure sender.
if it sitting on the same number all the time it seems that the sender has stopped sending a signal to the gauge while it was in operation at some point.
find where the oil pressure sender is, should be either on a sandwhich plate on the oil filter, or along the turbo oil supply line where it comes out of the block, and check that the plug is in properly.
