XR6TWolf Donating Members 176 Member For: 15y 10m 22d Gender: Male Location: Wellington New Zealand Posted 28/06/09 09:48 AM Share Posted 28/06/09 09:48 AM Ok, after another weekend of pampering the purple beast I have found that my attempt at getting that showroom shine was a failure.I opted for the Mothers 3 step kit. Used a random orbital for application of the first two steps.The first step worked well in terms of removing old wax and grime from the paint but appeared to have no impact at all in terms of removing the many swirl marks and scratches.....these are the type of scratches you would expect from going through a carwash for example, not deep but highly visible on a colour like Vibe.Nothing deep enough IMO to warrant a clay bar and in any case I lack the experience to be confident trying one.So...have I missed something....should there have been a mild cutting compound used either before step one or somewhere else along the way?Any tips appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/59021-polishing-without-the-desired-result/ Share on other sites More sharing options...
FPV6T UNDERCOAT CRUISER!!! Donating Members 1,655 Member For: 16y 3m 15d Gender: Male Location: brisbane Posted 28/06/09 09:52 AM Share Posted 28/06/09 09:52 AM have you tried a swirl remover? Link to comment https://www.fordxr6turbo.com/forum/topic/59021-polishing-without-the-desired-result/#findComment-897837 Share on other sites More sharing options...
wiresquire Member 266 Member For: 20y 5m 7d Posted 28/06/09 10:06 AM Share Posted 28/06/09 10:06 AM What exactly is in the Mothers 3 step kit?With a compound or polish, if it's heavy, it may actually create them. If the polish isn't heavy enough, it may not remove them. It's only as you get to lighter cuts or on to a swirl remover that you will see them disappear. Think the same as sand/wet-dry paper. Rough, lighter, lightest.My understanding is that a clay bar is used more to remove contaminants bonded to the paint rather than removing swirls and scratches. ws Link to comment https://www.fordxr6turbo.com/forum/topic/59021-polishing-without-the-desired-result/#findComment-897847 Share on other sites More sharing options...
400KwXr6t Member 129 Member For: 17y 8m 16d Gender: Male Location: Perth Posted 28/06/09 10:19 AM Share Posted 28/06/09 10:19 AM Yeah clay bar takes off built up grime salt residue etc, it won't fill in scratches and chips.its easy as pie to do and makes your paint feel like glass. You then polish and it looks a million bucks.You just gotta keep the lubricating spray under the clay. lots o lube is the way Oh and make sure you wash the car first it helps. Link to comment https://www.fordxr6turbo.com/forum/topic/59021-polishing-without-the-desired-result/#findComment-897862 Share on other sites More sharing options...
Bender Member 178 Member For: 17y 4m 26d Location: Newcastle Posted 28/06/09 10:21 AM Share Posted 28/06/09 10:21 AM I used claybar today, first time ever easy as piss. Just keep it lubbed and rub with the claybar. couldnt be any easier Link to comment https://www.fordxr6turbo.com/forum/topic/59021-polishing-without-the-desired-result/#findComment-897867 Share on other sites More sharing options...
chippa Slippery when dry Donating Members 368 Member For: 17y 9m 20d Gender: Male Location: Foot Hills W.A Posted 28/06/09 12:26 PM Share Posted 28/06/09 12:26 PM (edited) Just be careful using a claybar...one tiny bit of grit picked up in the clay and you can scratch the living sh*t out of your paint....make sure your paint is TOTALLY clean and be careful not to pick up any fine grit around or near wheel arches etc....I although very careful have unfortunately created some light marring in my ego paintwork using my clay...I now have to get out the R.O and using a swirl remover correct the paintwork....its very minor but I know its there which sh*ts me... Edited 28/06/09 12:28 PM by chippa Link to comment https://www.fordxr6turbo.com/forum/topic/59021-polishing-without-the-desired-result/#findComment-897939 Share on other sites More sharing options...
XR6TWolf Donating Members 176 Member For: 15y 10m 22d Gender: Male Location: Wellington New Zealand Posted 28/06/09 09:38 PM Author Share Posted 28/06/09 09:38 PM wiresquire said: What exactly is in the Mothers 3 step kit?With a compound or polish, if it's heavy, it may actually create them. If the polish isn't heavy enough, it may not remove them. It's only as you get to lighter cuts or on to a swirl remover that you will see them disappear. Think the same as sand/wet-dry paper. Rough, lighter, lightest.My understanding is that a clay bar is used more to remove contaminants bonded to the paint rather than removing swirls and scratches. wsStep 1 is California Gold Pre Wax CleanerStep 2 is Sealer and Glaze (This is the one I had hoped would deal with the swirl marks) and according to the Mothers website Regular application of Mothers® Sealer & Glaze will increase your paint’s depth and luster. Whatever the color, it will give your paint added character and a brilliant, glowing shine. Sealer & Glaze fills and hides minor swirls and defects, minimizing unsightly visual imperfections. It also contains a super-fine polish that further improves the paint surface. Sealer and Glaze is key to giving both light and dark colors their perfect finish.Step 3 is Carnauba wax (I used the liquid version)Not sure if that helps much Link to comment https://www.fordxr6turbo.com/forum/topic/59021-polishing-without-the-desired-result/#findComment-898010 Share on other sites More sharing options...
eicarsto Member 31 Member For: 15y 10m 27d Gender: Male Location: Brisbane Posted 28/06/09 10:22 PM Share Posted 28/06/09 10:22 PM I had the same problem with my previous car a Honda Accord Euro. No matter how hard I tried, how long I took, I just couldnt get it perfect.Until I went searching for the right stuff! I took a leap of faith and spent nearly $300 on a Zaino kit including the microfibre cloths. Being a Scottsman that was painful!Thought the missus would tear me a new ahole! As soon as I got it I used it on the Honda and was blown away by the results. I was so impressed I used it on my wifes Suzuki Swift Sport and she was delighted. It really is that good.The trick to using it is simple, less is more. You dont need a lot to get the best results which in turn doesnt make the product too expensive in the long run.I now use it on my FPV EGO and I can truthfully say it is still awesome stuff.Incidentally the body panels on a $70000 FPV are nowhere near as solid our well finished as a $40000 Honda! But the engine...hmmm the engine.Long story short, invest in some Zaino, spend some time perfecting how to apply, and you will be a happy man. I have had the same kit for over a year and still have plenty left.PS I always use human power..never orbitals.Wayne Link to comment https://www.fordxr6turbo.com/forum/topic/59021-polishing-without-the-desired-result/#findComment-898014 Share on other sites More sharing options...
wiresquire Member 266 Member For: 20y 5m 7d Posted 29/06/09 12:10 AM Share Posted 29/06/09 12:10 AM (edited) Step 2 is your problem. There's 2 different approaches to scratches and swirls. One is to polish to remove them which evens the paint/topcoat out, and the other is to 'fill them'. I'm not going to debate the pros and cons of each. The only thing I'll say is that most detailers tend to go for the polish rather than the fill. The Zaino kit mentioned above will probably include a polish...From the description you give, the Sealer and Glaze is mainly a 'filler' type product rather than an abrasive polish. So, if the scratches/swirls are still showing, then the 'filling' isn't happening properly, and it doesn't have enough abrasive power to remove the swirls. Can't really say what the issue is as each product is very different. Too much product, not enough, too much pressure on the OR, or not enough. It can be a pain. You are doing it in the shade with all the panels cool, right?BTW, there's a very informative thread here about the differences between polish, wax and the different types of stuff available.hthqs Edited 29/06/09 12:13 AM by wiresquire Link to comment https://www.fordxr6turbo.com/forum/topic/59021-polishing-without-the-desired-result/#findComment-898031 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 3m 1d Gender: Male Location: Sydney Posted 29/06/09 03:35 AM Share Posted 29/06/09 03:35 AM yep, zaino is the sh*t.use that in conjunction with a meguiars clay bar and she'll be applestoss the orbital to the woodworkers. Link to comment https://www.fordxr6turbo.com/forum/topic/59021-polishing-without-the-desired-result/#findComment-898081 Share on other sites More sharing options...
