  • Member For: 14y 2m 11d
Ok then that's slightly annoying considering they were suppose to be off a FG GT-P ill try and reverse the mounts tonight but the bolts lined up but where the struts are machined out they didn't fit on and the rears were off centre and the calliper pressed up against the disk when it was tightened! Im running out of posts today! I have 4 left and id really like to get this sorted tonight as I fly away to work in the next few days for 2 months!
Righto then, but when they were bolted on they seemed to press up against the inside of the disk.... I always thought the bleed nipples sit at the top? Yes some pictures would be handy. And im down in Rockingham (Perth) if that's not too far away?
ill go see if the piston has been pushed back fully now but I wont be able to test fit until atlest tomorrow arvo when I get access to a hoist. ill have to try and change the brackets, so I pretty much swap the left to the right?
how do you like them??? pull up okay? lol
Thanks heaps for your help, without this id be screwed!!
  • Member For: 16y 3m 24d
Okay so turns out the ones I brought are off a BA-BF (6 pots) so the brackets are the same, do I just switch the brackets around or do I have to change the cross over pipe as well?
It seems to be a long time since anyone posted on this! Apparently I have brought some brembos off a BA-BF thinking they were off a FG GT-P and im trying to put them onto a FG sedan, do I just swap the mounting brackets around? or do I have to change the cross over pipes? I already have the brake hoses.
hmmm ill have to give it a shot tomorrow morning! Fingers crossed it works! I suppose the brake hoses will be off a BA-BF too then
  • 10 months later...
  • Member For: 16y 3m 14d
So with 4pot brembo front's from a FG when I fit them to a BA all I need to do is switch the brackets and change the nipple and pipes from top to bottom and because the pistons are the same size they will be fine yes
