GCTXR6 Member 295 Member For: 16y 11m 29d Gender: Male Location: CANNINGVALE wa Posted 26/06/09 11:31 PM Share Posted 26/06/09 11:31 PM (edited) just thinking about upgrading to some bf f6 brembos and wondering if they fit a fg turbo aswell ,as I will upgrade most likely mid-late next year I already have fg f6 rims so they will be transfered to the new car so clearance is no issuethanks Edited 26/06/09 11:32 PM by GCTXR6 Link to comment https://www.fordxr6turbo.com/forum/topic/58968-ba-bf-brembos-fit-fg/ Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 17y 1m 8d Gender: Male Location: Blacktown! Posted 27/06/09 12:28 AM Share Posted 27/06/09 12:28 AM you will have to swap the mounting brackets from 1 caliper to the other, then you have to swap the metal lines on the caliper itself from the top to the bottom and also at the same time swap over the bleed valve from bottom to top. Then you need to get new brake lines as the BA-BF are longer and wont sit in the located bracket. Sounds easy doesnt it?This is all done due to the BA-BF caliper sitting at the front of the car on the wheel and FG sitting at the rear Link to comment https://www.fordxr6turbo.com/forum/topic/58968-ba-bf-brembos-fit-fg/#findComment-896996 Share on other sites More sharing options...
Guest Guests Posted 27/06/09 05:33 AM Share Posted 27/06/09 05:33 AM You will find that any of the brembos being sold atm that are brand new will be for FGs & not BA-BF, easily told apart by the mounting brackets as they changed. The 4 pots will fit both without changing anything as the pistons in the calipers are both the same size where as the 6 pots have 3 different sized pistons running largest to smallest. Link to comment https://www.fordxr6turbo.com/forum/topic/58968-ba-bf-brembos-fit-fg/#findComment-897130 Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 4m 9d Gender: Male Location: SoR, WA Posted 27/06/09 09:32 AM Share Posted 27/06/09 09:32 AM Correct as we just found this out last night.6 pots have 1 large and two small pistons. To fit to a BA/BF you require to have the crossover pipes made and nipples switched but the cross over pipes do not fit when swapped and require new ones made.. Gave them to a local Brake place today to make up and while they are there they are doing up some braided lines as well. Link to comment https://www.fordxr6turbo.com/forum/topic/58968-ba-bf-brembos-fit-fg/#findComment-897265 Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 4m 9d Gender: Male Location: SoR, WA Posted 27/06/09 09:34 AM Share Posted 27/06/09 09:34 AM ravenhard said: Then you need to get new brake lines as the BA-BF are longer and wont sit in the located bracket. Sounds easy doesnt it?I will have to disagree with this as we just fit a set to a BA yesterday with the FG lines. Link to comment https://www.fordxr6turbo.com/forum/topic/58968-ba-bf-brembos-fit-fg/#findComment-897266 Share on other sites More sharing options...
GCTXR6 Member 295 Member For: 16y 11m 29d Gender: Male Location: CANNINGVALE wa Posted 27/06/09 10:39 AM Author Share Posted 27/06/09 10:39 AM (edited) Thanks adrian ,so the long and the short of it is that if I buy some bf brembos and fit them to my ba (with some brake line replacements)I can return it to std and refit them to a fg turbo with the same changes(brake pipes again and fg brembo brakets ) here and there Edited 27/06/09 10:41 AM by GCTXR6 Link to comment https://www.fordxr6turbo.com/forum/topic/58968-ba-bf-brembos-fit-fg/#findComment-897325 Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 4m 9d Gender: Male Location: SoR, WA Posted 27/06/09 10:51 AM Share Posted 27/06/09 10:51 AM (edited) yep except I have some FG pipes that am willing to sell. Edited 27/06/09 10:51 AM by Adrian6T Link to comment https://www.fordxr6turbo.com/forum/topic/58968-ba-bf-brembos-fit-fg/#findComment-897336 Share on other sites More sharing options...
jacobmitchell92 Donating Members 370 Member For: 14y 1d Gender: Male Location: Perth Posted 28/09/12 01:25 PM Share Posted 28/09/12 01:25 PM Gday guys got a few questions hopfully some of you may be able to help me.First of all I have a 2009 XR6 Turbo and I am planning on putting 6 pot brembos on the front and 4 pot on the rears, I assume these just bolt straight on with the correct mounting brackets? or do I have to do some mods to such as the Master cylinder etc?Thanks!! Link to comment https://www.fordxr6turbo.com/forum/topic/58968-ba-bf-brembos-fit-fg/#findComment-1301945 Share on other sites More sharing options...
old_mate Member 767 Member For: 19y 1m 29d Gender: Male Location: Brisbane Posted 28/09/12 01:49 PM Share Posted 28/09/12 01:49 PM Bolt em up. No other changes required. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/58968-ba-bf-brembos-fit-fg/#findComment-1301949 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 8m 6d Gender: Male Location: Newcastle Posted 28/09/12 08:57 PM Share Posted 28/09/12 08:57 PM ^^^^ Agreed. Just make sure the wheels you have clear them.Benny. Link to comment https://www.fordxr6turbo.com/forum/topic/58968-ba-bf-brembos-fit-fg/#findComment-1302002 Share on other sites More sharing options...
