phoonme Member 8 Member For: 16y 30d Posted 26/06/09 12:30 PM Share Posted 26/06/09 12:30 PM hey guysgot to pick your brains. now my old car was a 95 falcon.new car is an 03 xr6 turbo 5 spd when I purchased the car the cooling line that runs from the thermostat to the turbo (in the area) with the hose that joins the two together was split. so I replaced it and was working fine. couple of weeks later its loosing coolant :-S so I check over all the lines and there is no sign of coolant loss anywhere. this has been going on for weeks and am starting to think that the turbo could be using coolant? what could be the problem. its deff not that hose anymore but it seems I have to keep topping it up. what could it be??? Link to comment https://www.fordxr6turbo.com/forum/topic/58963-seems-to-be-using-coolant/ Share on other sites More sharing options...
Rootster Just a large member member Silver Donating Members 3,125 Member For: 16y 6m 14d Gender: Male Location: sydney Posted 26/06/09 12:35 PM Share Posted 26/06/09 12:35 PM can you smell it......my ba was slowly leaking from the radiator side tank where it joined the core....was told common problem.....See if you can get the system pressure tested.....I lost more fluids when cold than on long drives....as the expansion of the tank/core sealed it.... Link to comment https://www.fordxr6turbo.com/forum/topic/58963-seems-to-be-using-coolant/#findComment-896851 Share on other sites More sharing options...
Driven By Shine Member 15 Member For: 16y 8m 16d Gender: Male Location: Gold Coast Posted 26/06/09 12:36 PM Share Posted 26/06/09 12:36 PM Not sure if we have a similar problem but.I also have a 03 XR6T that was leaking a tiny bit of coolent each night (about a 10c piece worth) I called by the mechanic and we did a pressure test. Everything was good. After telling him in not dreaming things he suggested that maybe when the engine cools down the parts contract and develop a leak but when the engines is hot they parts expand and seal the leak. So after doing some searching while engine was cold in the mornings I found the leak just below the thermostate housing, there is a metal pipe, this apperantly has an oring on it that had sh*t it self. We replaced it and everything has been fine since.Not sure if this helps you but it may.Chris Link to comment https://www.fordxr6turbo.com/forum/topic/58963-seems-to-be-using-coolant/#findComment-896852 Share on other sites More sharing options...
davidald Me Donating Members 360 Member For: 18y 1m 2d Gender: Male Location: Adelaide Posted 26/06/09 07:00 PM Share Posted 26/06/09 07:00 PM The split hose sounds like in the past it may have been running with the wrong coolant, just water, or maybe just not serviced. If this is so and you are sure it is not leaking then maybe a head gasket? Is it running hot? Link to comment https://www.fordxr6turbo.com/forum/topic/58963-seems-to-be-using-coolant/#findComment-896916 Share on other sites More sharing options...
phoonme Member 8 Member For: 16y 30d Posted 26/06/09 08:38 PM Author Share Posted 26/06/09 08:38 PM (edited) thanks for all the reply's ill look into it all. well im not sure if it could be head or not. 1 there is no excess pressure in the cooling system, 2 there is no trace of exhaust gas in the reservoir. 3 car is running perfectly normal in temp range. I just went over all the radiator hoses to find the top left hose (10-15mm) in diameter loose with water marks running down it. will drive around for a couple of weeks and see if it has coolant level has droppped. tomorrow if I have time ill pull the plugs out and inspect them to see if its detonating with water in the chamber. also the car has a bit of a rough idle. its done 104000 now. and on the last service was at 93,000 for plugs. did oil last weekend. :-) Edited 26/06/09 08:41 PM by phoonme Link to comment https://www.fordxr6turbo.com/forum/topic/58963-seems-to-be-using-coolant/#findComment-896917 Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 17y 1m 27d Gender: Male Location: Blacktown! Posted 26/06/09 11:03 PM Share Posted 26/06/09 11:03 PM I had a slow leak from the pipe going to the turbo, I couldnt find it anywhere until I took it in for a service. My mechanic had it on the hoist and found it as it was below the turbo he could see white stains from where the coolant had dried. 1 brass washer later and all fixed. Link to comment https://www.fordxr6turbo.com/forum/topic/58963-seems-to-be-using-coolant/#findComment-896950 Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 16y 11m 7d Gender: Male Location: sunshine coast Posted 26/06/09 11:17 PM Share Posted 26/06/09 11:17 PM A nice little trick if you still cant find it is to take it for a drive and park it in your garage, cover the floor with white paper under the engine bay and check for green stains in the morning. Should help you pin point where its coming from Link to comment https://www.fordxr6turbo.com/forum/topic/58963-seems-to-be-using-coolant/#findComment-896956 Share on other sites More sharing options...
