Fitted Hdi Hybrid Kit
xrturbomatty
  • Replies 118
  • Member For: 18y 11m 25d
you have to cut the lip off the reo bar and they also hang mega low.
As ETM said ...If you cut a bit off the reo it will look like this about 5-7mm from each edge of it
And I used some of Chris RAPIDS Pipes up to the throttle body from the cooler and used bits and pieces from the old hybrid set up.. the hybrid coolers do what they have too. , its the perfect cooler for my setup, as run an engine oil cooler above it, which let me retain the washer bottle, the cooler gets direct airflow to over 95% of it and oil cooler does as well, the Reo actually stops about 30- 40% of direct airflow with a lot other coolers on the market ... bigger is not always better in my opinion. and this hybrid cooler way out performers its predecessor ( I had the old Hybrid set-up on it before) the old one made about 330 17-15 psi and this setup makes 340 15-14 psi on the CV tune and 375 on 18 with the HPF tune with the AFR's dunking in to the high 11's right up top on both tunes .. time after time .
Good choice xrturbomatty :spoton:
Edited by stealthxr
  • Member For: 16y 4d
looks good hustla, anyone out there have a pic of it on a bf? only one ive seen is a bionic bf and the cooler sits lower than the bumper, if its posible to get them higher on the bf like hustla's ba ill get one
  • Member For: 17y 10m 19d
There is no reason why you could not get it to fit like that on a bf but you do have to cut to get it up that high, It wont go any higher than that though.
  • Member For: 15y 9m 7d
hey there guys.
I too have fitted the new hybrid cooler kit. real good product! im mega happy that's for sure!
Few pics below. just got one question, are all the standard intercoolers on the xr6t an FPV unit? my 2004 is the luxury model but the old coller had a bit FPV stamp on it. Any ideas?
cheers guys
