Rear Tail Light Problem.
Jimbob
  • 2 months later...
  • Cruise Whore
  • Moderating Team
  • Member For: 19y 6m 6d
Good enough for me masda74 ... :roflmbo:
Hey guys I tried to tap into the electrical wiring loom that feeds the rear lights.  I think its for the tow bar nominal 12V but I what I didn't check was whether it could handle current draw for a cig lighter socket in boot of car.  Apparently not (ba bonggg).  Or I'm not doing something right.  Here's a pic of just before I tapped into it.  I checked with a multimeter and am getting 11.6V in the socket itself but when I plug my rear car cam plug into it - nothing happens.
So is there another 12V line accessible in the boot that I can tap onto?  Or do I have to run my own line from somewhere near the front tapping onto the ACC supply line that feeds the front dashboard cig lighter? :beerchug:
  • WOT?
  • Moderating Team
  • Member For: 11y 11m 17d
I think there's a 12v "accessory" plug through the towbar plug thing? (allows you to run 12v to the caravan etc)
  • Puff
  • Member For: 10y 13d
There are three 12v pins in the towing loom that could be used.
Without the tow loom plugged in it'll just be a matter of doing what Gaz has already done, finding a 12v source from the back somewhere.
  • Cruise Whore
  • Moderating Team
Yep I dont have the towing loom which is a separate loom added on when you get a tow bar (I believe).
What about anyone who has needed to power a Sub Woofer amp?  I've checked those threads but did find anything immediately.
Someone must have done something like this already?
  • To Loud
  • Member For: 13y 2m 12d
you have to turn the car on for the cigarette lighter to work EVildaifu...... :P
Maybe that is your problem with the one connected at the rear?
:surrenderwave:
