  • Member For: 16y 8m 27d
you shouldnt need to go to an rta testing center for a noise test. For engineering you can get it done just about anywhere so I'd imagine this would be the same. Emissions on the other hand means a trip to botany or penrith.
As I said before, if you are borderline and intend on changing it later anyway just put some steel wool up there. It will wear away shortly after the test. Its a common trick and you can change it in your own time.
