400KwXr6t Member 129 Member For: 17y 3m 6d Gender: Male Location: Perth Posted 20/06/09 02:23 AM Share Posted 20/06/09 02:23 AM Hey all I got a pair of front typhoon discs of a mate as he upgraded.Question is where do I get an adaptor bracket to space the caliper out. Its a standard BA caliper. Would love to get 4/6 pots but finances dont allow it, and I could spend the $$ on other projects.Has anyone done this or is there something that interferes or does not line up.I have 18" rims so hope they fit under there too.Any help much appreciated as it will save me time test fitting and finding out they do or dont fit the hard way. Link to comment Share on other sites More sharing options...
RBSMATT New Member 18 Member For: 16y 7m 15d Gender: Male Posted 26/06/09 06:39 AM Share Posted 26/06/09 06:39 AM You can't space a sliding caliper out for a thicker rotor if that is what you mean but on the other hand if you mean to raise the caliper higher to fit a bigger diameter rotor that is a different thing and although we do not do them it will also depend on what the actual rotor size is you want to fit it to. Link to comment Share on other sites More sharing options...
400KwXr6t Member 129 Member For: 17y 3m 6d Gender: Male Location: Perth Posted 26/06/09 08:44 AM Author Share Posted 26/06/09 08:44 AM yeah I understand the caliper only has limited travel but didnt think to measure the disc thickness yet. pretty sure they wont be too much different and should fit.What I want to do is put a bigger diameter disc on and keep the standard calipers.Have searched the net for brackets but couldnt seem to find any, and being busy at work hasnt allowed me to go round to brake shops to ask.just thought I'd take the easy (lazy) way and ask if anyone had done it or known of someone who had Link to comment Share on other sites More sharing options...
gassa Member 42 Member For: 15y 9m 21d Posted 18/07/09 04:51 AM Share Posted 18/07/09 04:51 AM MateWern't Ba Pads thinner than bf , They reduced the thickness on the rotor and increased the pad thickness unless u chase half worn pads what thickness difference is theregassa Link to comment Share on other sites More sharing options...
RBSMATT New Member 18 Member For: 16y 7m 15d Gender: Male Posted 20/07/09 02:02 AM Share Posted 20/07/09 02:02 AM (edited) MateWern't Ba Pads thinner than bf , They reduced the thickness on the rotor and increased the pad thickness unless u chase half worn pads what thickness difference is theregassa BA BF with twin piston non FPV calipers have either 298mm or 322mm front disc rotors that are 28mm thick and take the same brake pads. Edited 20/07/09 02:04 AM by RBSMATT Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 3m 17d Gender: Male Location: Newcastle Posted 20/07/09 03:38 AM Share Posted 20/07/09 03:38 AM Matt,Good to see you on the forums here. I'm sure you could answer many brake questions that get asked around here. My brakes you supplied are going great and handled Wakefield no dramas.Benny Link to comment Share on other sites More sharing options...
RBSMATT New Member 18 Member For: 16y 7m 15d Gender: Male Posted 20/07/09 03:52 AM Share Posted 20/07/09 03:52 AM ]Thankyou and good to hear all is well. Link to comment Share on other sites More sharing options...
ALF05T Member 453 Member For: 17y 10m 8d Gender: Male Location: Sydney Posted 20/07/09 09:00 PM Share Posted 20/07/09 09:00 PM To answer your question the 355mm rotors fit under BA 18" wheels (just)!As for your 4 pots, you already have the rotors. You may get some second hand ones cheapoff the forum for a bit over a grand. Link to comment Share on other sites More sharing options...
bentles Member 121 Member For: 16y 1m 24d Gender: Male Location: melbourne Posted 23/07/09 10:25 AM Share Posted 23/07/09 10:25 AM no wont fit.how can u fit a 32mm wide disc into a caliper designed for 28mm discs..... Link to comment Share on other sites More sharing options...
