  • Member For: 17y 28d
hey guys well the worse happened on the weekend my motor died :beerchug: ohh well sh*t happens just wish it did not happen right now..
I will be geting an atomic 600kw short (but aparently 698kw now according to Brad) / or they will be re building mine if the block is not to damaged..
just wondering what other things will be worth while changing while the motor will be out?? any ideas
I will be getting new billet oil pump gears and the lil modification they do to the housing too..
what kind of power levels is it worth getting a girdle??
I no I will be limited to the stock turbo but I might up grade later on so is it a worth while as like I to do things once..
any ideas welcome cheers
https://www.fordxr6turbo.com/forum/topic/58628-new-short-motor/
  • Replies 176
Posted Images
  • Member For: 17y 3m 16d
Sorry to hear this, but do you think the blown motor was cuased by going the CAI and overboosting? if so Im heaps worried for my own motor now!
Edited by ravenhard
who knows.. all I did was leave my mates house changed 1st to 2nd then just as I changed to third it went bang.. with a back fire still was ok for about 500m then just started dieing so turned it off.. probably done piston rings or bent a rod.. it was not over boosting or anything at the time..
it has no compression as you can turn the crank over by hand with a breaker bar.. when I get the motor out it will be going to atomic..
Edited by CHLAXN
  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 19y 1m 15d
oil pump gears 100% if there not in the atomic kit. And I would fully reco the head even if there is no visiable sign of damage.
Edited by YPURV4
  • Forged Member
  • Member For: 18y 4m 12d
100% on the oil pump mate. Girdle is a good safety thing, they stop the main caps walking around and will allow you to push the rev limit a bit higher when you go for a bigger turbo. Depending on how much boost you are running you can look at the 12mm head studs too. I'd also throw an Atomic Harmonic Balancer on it too, the stock ones aren't the best thing in the world.
Good Luck! :stupid:
yeah defently doing them lol.. yeah they dont come with the short motor lol... as the car has 99000 k's he said I wood need to reco the head so that will be done too.. thanks for that mate..
did you end up having to replace anything else with your build as I think you had similar k's??
  • Member For: 16y 4m 9d
  • Gender: Female
Mate get a head stud kit they are $350 a set. Im glad I did it as im about to bolt on a GT42 and push it to 30psi and would not of been able to do it without the head stud kit..
Good Luck with it.
