  • Member For: 20y 7m 14d
Surely its over 9psi, I peak at 12psi then run off to 10psi and I'm only running 278rwkw. I know the BFs produce higher numbers but that's a big jump over mine with less boost, and that curve is a wall. Would be very fun to drive.
  • Replies 33
  • Member For: 16y 5d
BLK6T what over mods have you done to your BA to get 278rwkw's? I've heard manuals have a few more kw's then an Auto.... NOSXR did a dyno test on the 20% underdrive with an xr6t & gained 11kw's, the center muffler is a restriction & now with straight through pipes it's more free flowing & the hyperflow CAI with the K&N filter makes it breath a lot better too, for the car to pull 304.3rwkw's I'm stoked & yes it's a blast to drive.
Jaymen,
My only mods are tune and injectors, result 278 rwkw. The guys at CV said the center muffler is a restriction and the intercooler, if I replace both it would flow much better.
Who did your center muffler change and did it alter the noise by much?
Good result on your car though!
City muffler in Nowra did my center muffler for $50 & yes it does alter the sound but I reckon it sounds heaps better, a Gutted cat or Hiflow 100cell cat is needed now as well.... yeah the intercooler is only good for 300-310rwkw's & then heat soak is an issue so that's the next thing on my list of goodies.
