supercharged88 Member 153 Member For: 16y 6m 7d Gender: Male Location: Far Nth QLD. Posted 28/06/09 07:45 PM Author Share Posted 28/06/09 07:45 PM (edited) No I havent done the install yet.The owner is sourcing new engine parts to repair the damage that occured when it was previously tuned by another tuner.Did you install the SM4 on your car.Did you have to modify the sensor teeth to work with SM4.Yes it is a BA. Edited 28/06/09 07:47 PM by supercharged88 Link to comment Share on other sites More sharing options...
Sprjenkins Member 52 Member For: 16y 6m 12d Gender: Male Location: Melbourne Posted 29/06/09 12:24 PM Share Posted 29/06/09 12:24 PM The Flash Tune isn't quite the bees knees, my AU XR6 wont run on anything other then an Aftermarket ECU, the Cam Shaft is just way to big. Link to comment Share on other sites More sharing options...
XR64LT Donating Members 678 Member For: 17y 25d Gender: Male Location: sydney Posted 30/06/09 08:53 AM Share Posted 30/06/09 08:53 AM http://www.rigoli.com.au/xrsex.html Link to comment Share on other sites More sharing options...
supercharged88 Member 153 Member For: 16y 6m 7d Gender: Male Location: Far Nth QLD. Posted 16/07/09 08:12 PM Author Share Posted 16/07/09 08:12 PM I am planning to install an autronic sm4 in the coming weeks on my ute with the fly by wire boxHow are you going with your SM4 install ?Have you had a chance to start the project. Link to comment Share on other sites More sharing options...
beauies Member 209 Member For: 21y 4m 11d Gender: Male Location: sydney Posted 17/07/09 10:26 AM Share Posted 17/07/09 10:26 AM Not so far my turbo van had a stuck valve and a crack through its head so its received all the priority at the moment. Tuning tomorrow if all goes to plan.All the parts have arrived except I havn't purchased my M & W CDI unit yet so as soon as I purchase that I will start.Check back in a couple of weeks and see how much hair I have left on my head. Link to comment Share on other sites More sharing options...
supercharged88 Member 153 Member For: 16y 6m 7d Gender: Male Location: Far Nth QLD. Posted 17/07/09 07:45 PM Author Share Posted 17/07/09 07:45 PM Yeah, that's why I shave my head bald, it used to hurt when I pulled my hair out Link to comment Share on other sites More sharing options...
Redback Banned 236 Member For: 15y 7m 22d Gender: Male Location: Blacktown NSW Posted 17/07/09 09:32 PM Share Posted 17/07/09 09:32 PM Aftermarket ECU is the way to go when then engine has been modified way past the factory parameters. I use to fit and tune Microtech. Not as advanced as Motech and Autronic in respect to closed loop etc. but when you can live tune you spend 45min or so on the dyno and the car is sorted. Also the factory ECU isn't capable of correctly managing boost pressures of 20psi+. Hence an aftermarket with 3bar map is ideal. Good luck with your project supercharged88! Link to comment Share on other sites More sharing options...
HIRO F6 Member 1,817 Member For: 16y 13d Gender: Male Location: Brisbane, QLD Posted 17/07/09 11:46 PM Share Posted 17/07/09 11:46 PM Sorry if im dumbing down this thread, but im about to go through the process of chosing an aftermarket ECU.How much should I be budgeting? My car is an FG and we will be chasing 600rwkw. Will I keep my current dash functions or just go to a digital dash? Link to comment Share on other sites More sharing options...
HIRO F6 Member 1,817 Member For: 16y 13d Gender: Male Location: Brisbane, QLD Posted 20/07/09 04:46 AM Share Posted 20/07/09 04:46 AM Ive spoken to alot of people about aftermarket ECU's in the last week. Spoke to Motec and it looks like it wont work the auto box. That's the same with ViPEC. Looked into a Haltec system which ticked most of the boxes except fly by wire!!! That and my tuner isnt the biggest fan of Haltec.Im starting to think im kidding myself trying to get over 500rwkw with the auto box.Any advice would be appreciated. Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 10m 3d Gender: Male Posted 20/07/09 06:32 AM Share Posted 20/07/09 06:32 AM (edited) I have piggybacked on older falcons but not the B or F seriesYou just piggyback fuel/ ignition/ cams etc and let the original computer do the rest. The auto should change as normal, you may have to double up on some sensors like the air temp and water temp but the TPS should not need duplication.You can just start by piggybacking fuel then once you have that sorted start doing the othersOn E series cars I can exceed stock drivability and even stock cold starts but it takes alot of work and touching up of the map which can only happen when you are driving around and adjusting bit by bit.A tuner who just has it on the dyno and drives around the block for 45min cant do it. It takes alot of touching up over different whether conditions to get good drivability and startup.No ECU system will do the 6sp auto Edited 20/07/09 06:35 AM by turbotrana Link to comment Share on other sites More sharing options...
