b-rad Donating Members 257 Member For: 16y 8m 12d Location: townsville Posted 10/06/09 08:23 AM Share Posted 10/06/09 08:23 AM when you remove the ICC the car wont start dose anyone no why/what causes this has anybody managed to start car with no ICC my end goal would be to not have an ICC in at all as there will be other things there instead Link to comment Share on other sites More sharing options...
ENVYOSXR Loves boost Donating Members 266 Member For: 15y 7m 23d Gender: Male Location: VIC Posted 10/06/09 09:55 AM Share Posted 10/06/09 09:55 AM Im not 100% sure, and someone might correct me here but I don't think it is really possible to start your car without the ICC installed. When I removed mine nothing would work, it seems to be the brains of the car.Can I ask why you want it completely gone? Link to comment Share on other sites More sharing options...
b-rad Donating Members 257 Member For: 16y 8m 12d Location: townsville Posted 10/06/09 10:28 AM Author Share Posted 10/06/09 10:28 AM working on replacing it with touchscreen to control all the ICC functions Link to comment Share on other sites More sharing options...
ENVYOSXR Loves boost Donating Members 266 Member For: 15y 7m 23d Gender: Male Location: VIC Posted 10/06/09 11:18 PM Share Posted 10/06/09 11:18 PM anything is possible I suppose, but I think that will be quite a lot of work.Good luck to you! Link to comment Share on other sites More sharing options...
sicklaser Member 183 Member For: 18y 4m 15d Location: Mackay QLD Posted 11/06/09 06:17 AM Share Posted 11/06/09 06:17 AM im not 100% but I think you only need the plastic boxes on the back of the icc for the car to run Link to comment Share on other sites More sharing options...
dashturbo Donating Members 280 Member For: 16y 5m 16d Gender: Male Location: Watsonia Posted 11/06/09 06:34 AM Share Posted 11/06/09 06:34 AM I assume its like smartlock of old, where if it recognises any change in its instrument cluster or ingnition barrel it goes into 'lockdown'. You might be able to get the dealer to overide, or maybe by reprogramming the keys.. But you would need to trick the computer into thinking that the same ICC is plugged in. you would need to work out all the HVAC controls and stuff too I assume? Link to comment Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 18y 8m 20d Gender: Male Posted 11/06/09 07:27 AM Share Posted 11/06/09 07:27 AM You need the ICC for it to work.. other wise car wont start even if you bypass that, the icc controls the cluster etc, im putting a custom lcd screen in mine but im still using the icc just ripping out all the sht above the heater controls.And I doubt you can get the icc standed functions to be displayed on an after market screen.Idd like to be proven wrong though. Link to comment Share on other sites More sharing options...
ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 19y 7m 25d Gender: Male Location: Melbourne Posted 11/06/09 08:28 PM Share Posted 11/06/09 08:28 PM The main reason is that the ICC is in the middle of the Can Bus. I have heard some small success with the icc out and bridging the Can Bus lines so that they continue to the next modules. Link to comment Share on other sites More sharing options...
jammin Member 3 Member For: 15y 6m 12d Posted 15/07/09 07:38 AM Share Posted 15/07/09 07:38 AM you can start the car without the icc, it is 100% possible. you need to leave the bcm (body control module in) that is the plastinc box screwed to the bottom of the icc with all the connectors plugged into it. Link to comment Share on other sites More sharing options...
b-rad Donating Members 257 Member For: 16y 8m 12d Location: townsville Posted 15/07/09 07:50 AM Author Share Posted 15/07/09 07:50 AM you can start the car without the icc, it is 100% possible. you need to leave the bcm (body control module in) that is the plastinc box screwed to the bottom of the icc with all the connectors plugged into it.interesting will have to give this us a shot tonight @ YPURV4 I really hope to prove you wrong ATM im 80% positive I will but time will tell Link to comment Share on other sites More sharing options...
