  • Member For: 17y 7m 7d
Hey guys,
My car's developed a slight problem sometimes (very intermittent) where it will sometimes completely stall when you are down changing and coming to stop.
It has only happened around 3 times in 2 weeks, and is very hard to pin point.
I was maybe leaning towards coils, as im getting "Coil A circuit fault" in the error log of the computer. I am going to change them this weekend anyway..
Just wondering if anyone else has experienced anything like this before? And if one coil was giving an error, whether or not the car would just stall intermittently?
Car is a BA MKII XR6T 6 Speed manual, with NKG 0.8mm iridium plugs, nizpro valve springs, fuel pump, injectors, etc.
Cheers guys.
Edited by Christiaan
  • Hey guys, Tab is here... Oh i feel sick
  • Member For: 16y 10m 27d
I have the same problem, can you explain your problem a bit more.
mine happens when I change down from 3rd to 2nd and it starts to sound real rough/back cackle/spluttering (like a rally car), then I push the clutch in and it dies, but if I tap the accelerator it smooths out. its not every time but nearly every time. mine is due to a fault that is causing it to not go into vacuum and sit on 4psi, I think its a faulty boost solenoid but will soon find out when I change it. is this like what you are experiencing?
oh and my car is exact same model and mods as yours
Edited by turbo.vixen
Umm nah mine doesn't cough and splutter. Mine just completely and smoothly stalls. The engine speed just slowly drops from 2000rpm, gets to 750 and instead of stopping and idling it will just keep smoothly dropping until it stalls. It doesn't cough splutter or anything, which is why I'm at a loss as to what's causing it.
The car runs fine and makes good power, and this doesn't happen everytime, only 3 times in 2 weeks..
I'm completely baffled :(
  • Member For: 16y 3m 17d
we had this happen in our xr8 it happen at roundabouts all the time we book it in at ford they told me it was the powersteer switch they replace it we pick ypu the car and at the first roundabout it stall got home rang them after a lot of to and through the came and pick the car up two day later they told me it was all ok pick it up and it was still the same
so I had a look over the car and found that 2 cell in battery had no water in them replace the battery and it was all good
steve
Thanks HID.
I got the codes extracted from the computer, and only the code about the coils came up.
Hopefully that fixes it.
I checked my battery cells and some were down on water so I filled them up.
Thanks again
  • Member For: 17y 7m 8d
mine does it to same model car. Been doing it for ages. Its really funny sometimes won't happen for weeks then twice in one trip. Been back to tuner several times to no avail. So be intreseted if ya find a solution.
Well I hate things like this happening, and it seems some people have this issue as well. I can't and won't rest until I find a solution.
I will change things and let you know what I find!
Just took the car for a quick drive, and it happened again. This is pretty disheartening to have this happen in a near new car. I keep the thing very well maintained.
If the coils don't fix the problem, I'm at a loss with what to try next. there are no other major error codes in the ECU, and the car's only done 60,000km's. Last thing I want to do is go changing all the expensive sensors for a problem that seems to only appear 2% of the time. It's not even a rough idle/stall, it just drops down and stalls very smoothly. :3gears::cry::msm: :wacko:
The car runs like a dream the other 98% of the time!
Changed the coils to these:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=370213569404
No sign of stalling yet. Power is a lot smoother and there is no more surging during coasting. Also changed/flushed the coolant today.
I will let you guys know how it goes. Fingers crossed this fixes the problem.
  • Member For: 17y 4m 12d
I had this happen in my old Expensive Daewoo barina.. Coming to roundabouts and it would stall its pretty sh*t loosing power steering. And makes you look like a nob who can't drive when you're at the roundabout turning the key to start the heapa
