  • Member For: 10y 2m 5d
Thanks for that. Why the corrugated? Just to help set the depth correctly without kinking a normal hose when installing, or a longer term reason?
Actually ignore me. Did some more research and I think I will loop some hose and if that turns out to be too difficult to work with, I'll order these:
https://www.efihardware.com/products/2524/Submersible-Flex-Fuel-Hose-E85-Compatible-150mm-Long
  • 7 months later...
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 18d
it's a quite similar process, just more of a squeeze to fit it in. You'll be fine following the instructions in this thread.
  • 3 months later...
  • Site Developer
it's just a bunch of screws around the edge of the circle mount.
for the fuel lines, there's a bit of finessing with where you apply the pressure (a pick set is a very valuable tool to use for those connectors) to get them off the 3 fuel line connections (make sure to re-connect them in the same order, e.g. mark which is which).
if you mean the bit of grey plastic over the top of the whole thing, just un-plug the obviously removable bit and then lever under the edges with a flat-head and pull upwards to remove it
  • Member For: 10y 4m 29d
  • Gender: Not Telling
Step one: Try to rip it out with your fingers for five minutes, then give up in frustration.
Step two: Lever it with a screwdriver.
  • Like 2
