Ross Bille Member 22 Member For: 13y 4m 13d Gender: Male Posted 02/09/12 11:37 AM Share Posted 02/09/12 11:37 AM I was going to do my fuel pump today, the car is a bf2 xr6t and the metal ring isn't held down by the 4 screws as it says in the first post.Its got some sort of twist lock system.I could not get it to budge today. can anyone tell me how to get it off? Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/8/#findComment-1288778 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 11m 19d Gender: Not Telling Posted 12/12/12 03:35 AM Share Posted 12/12/12 03:35 AM Quick update. Took probably 30 mins to install, 20 of which was spent trying to get the fuel line off. In the end it was simple. First I sprayed a little WD40, then just push the plastic connector back and then forward, dont try and push clips in you should be able to see the connector move a little forward. Then I used some needle nose pliers and applied some pressure to the larger side clips and pulled back, presto came straight off. The new cradle had a different style clip for the fuel gauge sender, didn't matter, just jammed it in and works perfectly. Just to give you an idea of size difference I have added this photo link. The screwdriver is the biggest flat blade I own.http://s1191.beta.photobucket.com/user/Impellor/media/Walbro%20255lph%20Big%20Pod%20Cradle/FuelPump866.jpg.html#/user/Impellor/media/Walbro%20255lph%20Big%20Pod%20Cradle/FuelPump866.jpg.html?&_suid=13552828247340053492653733534845Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/8/#findComment-1336202 Share on other sites More sharing options...
NickBA-XR6T Bronze Donating Members 386 Member For: 13y 3m 27d Posted 17/01/13 09:53 PM Share Posted 17/01/13 09:53 PM Doing this tomorrow. Hope I get it right! Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/8/#findComment-1350981 Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 9m 26d Gender: Male Location: sydney Posted 22/02/13 05:46 AM Share Posted 22/02/13 05:46 AM im going to try the whole drop in assembly for $285 + shipping from ebay ,sounds a lot easier.http://www.ebay.com.au/itm/FALCON-BA-BF-XR6-TURBO-XR8-WALBRO-GSS340-BIG-POD-FUEL-PUMP-COMPLETE-ASSEMBLY-/290811246355?pt=AU_Car_Parts_Accessories&hash=item43b5b37713 Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/8/#findComment-1365508 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 8m 19d Posted 22/02/13 05:49 AM Share Posted 22/02/13 05:49 AM I agree!! For the bit extra price it'll be much easier to do! Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/8/#findComment-1365512 Share on other sites More sharing options...
bigmat Donating Members 87 Member For: 18y 1m 5d Gender: Male Location: Gisborne NZ Posted 19/05/13 06:51 AM Share Posted 19/05/13 06:51 AM Just did mine today but fitted the 400 LPH Walbro pump inside the standard bucket Because it is that much bigger it was a bit of a mission reshaping the bucket removing all the ribbing around the return pipes for the filter, I then in the end put the standard filter back on the walbro pump with the clips removed. The one that came with the 400 lph pump just wouldnt fit inside the canister. I think if I do it again I will just buy a 400 LPH pump and larger canister, will see how this one performs. (Im watching AFR closely)..The BF had the bayonet clip in fittings instead of the screws and also just cut the factory wires off at the pump ends and soldered the spade terminals on directly to these wires, grey to +ve black to -ve no problems. , did the 360 loop in the fuel line so plenty of movement there actually better movement now than factory one... the fuel lines strangely enough only had a in and out no line for a carbon canister return,... found those clips easy to undo just light pressure with tiny screwdriver in the end next to the white pipe across three of the sides came awat easy as. and positve clip back on.. Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/8/#findComment-1390678 Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 9m 26d Gender: Male Location: sydney Posted 20/08/13 04:01 AM Share Posted 20/08/13 04:01 AM anyone done the aeromotive pumphttp://www.ebay.com.au/itm/Aeromotive-11141-340-stealth-fuel-pump-/261266082912?pt=AU_Car_Parts_Accessories&hash=item3cd4ac0c60 Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/8/#findComment-1417342 Share on other sites More sharing options...
jasol Member 571 Member For: 16y 5m 10d Location: adelaide Posted 16/12/14 08:59 AM Share Posted 16/12/14 08:59 AM Is this the same for fg? Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/8/#findComment-1517877 Share on other sites More sharing options...
tsv83 New Member 1 Member For: 9y 4m 18d Gender: Male Location: Sunshine Coast Posted 19/07/16 09:50 PM Share Posted 19/07/16 09:50 PM Hopefully someone can help me.... I found this thread excellent to get me to the point of getting the fuel pump out, but my FG MK2 sedan seems not to have the screws holding it in, rather a locked ring sort of thing... I've had a search around and can find plenty for the BA/BF but little in regards to the FG. Has anyone taken a fuel pump out of the FG and if so can you give me any pointers on how to get this ring "unlocked"?? or if there is a thread somewhere I have missed, could you point me in that direction.... Cheers and thanks in advance Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/8/#findComment-1602040 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 2m 16d Gender: Male Location: Canberra ACT Posted 27/04/18 12:13 PM Share Posted 27/04/18 12:13 PM Just chucking a Walbro 255 in my BA. This thread was super helppful. All done, just need to grab some hose and clamps in the morning to finish it off. I'm going to replace the supply and return lines in the cradle.A couple of questions that you lot might be able to help with:1. Do you guys like to install the sleeve that comes with the pump or not worry?2. I've got a few left over clips, washers, etc. and what looks like maybe an extension piece for the filter attachment. I'm assuming the kit caters for a range of installation scenarios and this is normal?I found the quick connect hose fittings external to the cradle popped off almost straight away with a pair of needle nose pliers. But the flexible, corrugated lines inside the cradle were an absolute PITA to cut free. Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/8/#findComment-1656342 Share on other sites More sharing options...
