trevs Member 781 Member For: 18y 7d Gender: Male Location: balmain Posted 04/07/09 10:51 PM Share Posted 04/07/09 10:51 PM great write up but how much fuel came out when you cracked the fuel lines ive been thinking im gonna pull the fuel fuse while the car is at idle and let it run out of fuel to avoid some of the mess anyone else done this ?cheers trev Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/3/#findComment-901304 Share on other sites More sharing options...
Phooned Member 72 Member For: 17y 10m 21d Gender: Male Location: SE Melbourne Posted 05/07/09 01:27 AM Share Posted 05/07/09 01:27 AM (edited) trevs said: great write up but how much fuel came out when you cracked the fuel lines ive been thinking im gonna pull the fuel fuse while the car is at idle and let it run out of fuel to avoid some of the mess anyone else done this ?cheers trevHey Trev,I have done this. I pulled the fuse when the car was at idle. I then gave it a few minutes and turned it over (with the fuse off), the engine started and stalled again. I had just under 1/4 tank of fuel and the range was 139Ks. Just watch out for the sender wire when you disconnect them, they seem to head straight to the bottom of the tank!There was just a trickle from the lines when I did mine this way. No mess.Cheers,AJ Edited 05/07/09 01:32 AM by Phooned Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/3/#findComment-901372 Share on other sites More sharing options...
trevs Member 781 Member For: 18y 7d Gender: Male Location: balmain Posted 05/07/09 05:03 AM Share Posted 05/07/09 05:03 AM cheers phooned my fuel pump is in isnt really that bad a job to do yourself besides un doing thoses f*cking fuel lines of which I broke two of the little clips off on the return line still holds the hose on but that *beep* never coming off again without the little clips on the side to push forward for removel checked for leaks pulled on all of them and everything is fine with the car running befor putting the back seat back in cheers trev Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/3/#findComment-901461 Share on other sites More sharing options...
civillian Donating Members 78 Member For: 20y 7m 11d Gender: Male Location: Canberra Posted 06/07/09 09:01 AM Share Posted 06/07/09 09:01 AM Update: Fuel has become green from the green heatshrink, but not as badly as I would have thought. Heatshrink is still intact; very slow degrading when submerged. Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/3/#findComment-902131 Share on other sites More sharing options...
trevs Member 781 Member For: 18y 7d Gender: Male Location: balmain Posted 06/07/09 09:37 AM Share Posted 06/07/09 09:37 AM fuel rated heat shrink ( neoprene ) costs a crap load of money ive used it in the past at work a few times to seal connectors its about 300 or 400 bucks for each boot about the size of small coke bottle I just used the crimps that came with the pump or you can buy them from jcar, dicksmith or if you really want to go overboard 3m electrical make some stuff as well but I really wouldnt be that worried about it as long as what ever ou use stops a dead short from happening after all the pump sits in fuel and the conector on the end of the fuel pump isnt sealed cheers trev Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/3/#findComment-902176 Share on other sites More sharing options...
gu4800 Member 156 Member For: 18y 18d Location: Brisbane Posted 06/07/09 11:04 AM Share Posted 06/07/09 11:04 AM XAH03 said: now you have to join the ford wiring to the supplied Walbro wiring loom. I have seen this done with crimps/connectors but I soldered and heat shrinked mine Here is a much much better solution for this aspect:1) snip the factory wires off the plug that goes into the top of the cradle 2) strip enough wire back on the Walbro loom to join two female blade connectors*3) remove the old female blade connectors from the factory plug with a watch makers screw driver (the old "precision screw driver")4) insert the new female blade connectors joined to the Walbro loom into factroy plug5) plug back in to the cradleNo solder, no joining.* TIP: remove the old female blade connectors from the factory plug and take them down to Repco. They are not quite a standard female connector (from memory) but Narva make them. Just have a look at the Narva book and you'll find them. Oh, and the MUST have the locking lug on them so that they stay inside the plug.Something like this: CheersDan Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/3/#findComment-902257 Share on other sites More sharing options...
XAH03 Member 597 Member For: 17y 5m 30d Gender: Male Location: Cairns QLD Posted 06/07/09 11:18 AM Author Share Posted 06/07/09 11:18 AM trevs said: great write up but how much fuel came out when you cracked the fuel lines ive been thinking im gonna pull the fuel fuse while the car is at idle and let it run out of fuel to avoid some of the mess anyone else done this ?cheers trevwhen I did mine I had the car turned off, pulled the fuse then started the car, it ran for a few second then turned off. that got rid of most of the fuel in the lines trevs said: cheers phooned my fuel pump is in isnt really that bad a job to do yourself besides un doing thoses f*cking fuel lines of which I broke two of the little clips off on the return line still holds the hose on but that *beep* never coming off again without the little clips on the side to push forward for removel checked for leaks pulled on all of them and everything is fine with the car running befor putting the back seat back in cheers trevyep the connections are a pain in the a$$, they are a push-pull type of thing. Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/3/#findComment-902274 Share on other sites More sharing options...
Redback Banned 236 Member For: 15y 10m 17d Gender: Male Location: Blacktown NSW Posted 06/07/09 10:01 PM Share Posted 06/07/09 10:01 PM gu4800 said: Here is a much much better solution for this aspect:1) snip the factory wires off the plug that goes into the top of the cradle 2) strip enough wire back on the Walbro loom to join two female blade connectors*3) remove the old female blade connectors from the factory plug with a watch makers screw driver (the old "precision screw driver")4) insert the new female blade connectors joined to the Walbro loom into factroy plug5) plug back in to the cradleNo solder, no joining.* TIP: remove the old female blade connectors from the factory plug and take them down to Repco. They are not quite a standard female connector (from memory) but Narva make them. Just have a look at the Narva book and you'll find them. Oh, and the MUST have the locking lug on them so that they stay inside the plug.Something like this: CheersDanDid the same thing but instead of buying new terminals I was able to undo the crimp, insert the wiring in, crimp and solder. Worked a treat. Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/3/#findComment-902431 Share on other sites More sharing options...
civillian Donating Members 78 Member For: 20y 7m 11d Gender: Male Location: Canberra Posted 08/07/09 07:11 AM Share Posted 08/07/09 07:11 AM I've been working on a similar solution to Dan's aswell. That sounds like the proper proceedure to me... Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/3/#findComment-903155 Share on other sites More sharing options...
civillian Donating Members 78 Member For: 20y 7m 11d Gender: Male Location: Canberra Posted 10/07/09 03:52 AM Share Posted 10/07/09 03:52 AM Dan, could you supply the part number of the female blade connectors for our cars?N Link to comment https://www.fordxr6turbo.com/forum/topic/58327-sedan-fuel-pump-install-how-to/page/3/#findComment-904369 Share on other sites More sharing options...
