CraigH Member 100 Member For: 22y 5m 1d Location: Canberra Posted 12/06/09 08:00 AM Share Posted 12/06/09 08:00 AM Did you have to swap the pulley - did that require any special tools ? Link to comment https://www.fordxr6turbo.com/forum/topic/58307-mystery-power-steering-leak-ba-xr6t-try-to-work-this-one-out/page/3/#findComment-889757 Share on other sites More sharing options...
bluesmuso Member 144 Member For: 17y 9m 9d Gender: Male Location: South Australia Posted 19/06/09 07:38 AM Author Share Posted 19/06/09 07:38 AM (edited) Sorry Craig for not replying sooner, I have not looked at this thread for a while because it was the pump and the leak is just a bad memory now, no problems at all, no leaks and clean engine bay.No I didn't have to remove the pulley, it is part of the pump, just remove the 3 bolts holding the pump on (the pulley has holes in it to access these bolts from the front) and remove and replace the pump, very easy access (love these inline engines) once the serpentine drive V belt is off it's easy.Off topic but,today I hit a sharp kerb and tore a chunk out of my F/L tyre and damaged the rim (18X8 speedy envy mk III) cosmetic only no flat spot in rim. Bloody councils if only they kept their kerbs in good repair, this one had almost an inch of sharp concrete sticking out where a join had moved, and it was a curving road so parking parallel was difficult, as I stopped to pick up my son bang it hit (I'll need a wheel alignment to but it needed one anyway) .........not a good day for me, I complained to the council but they were not particularly interested. Edited 19/06/09 07:46 AM by bluesmuso Link to comment https://www.fordxr6turbo.com/forum/topic/58307-mystery-power-steering-leak-ba-xr6t-try-to-work-this-one-out/page/3/#findComment-893308 Share on other sites More sharing options...
civillian Donating Members 78 Member For: 20y 8m 13d Gender: Male Location: Canberra Posted 24/06/09 11:43 PM Share Posted 24/06/09 11:43 PM bluesmuso said: I complained to the council but they were not particularly interested.Get your concrete cutter out and do some community work! Link to comment https://www.fordxr6turbo.com/forum/topic/58307-mystery-power-steering-leak-ba-xr6t-try-to-work-this-one-out/page/3/#findComment-896009 Share on other sites More sharing options...
igsta Member 371 Member For: 21y 7m 21d Gender: Male Location: Sydney Posted 25/06/09 06:18 PM Share Posted 25/06/09 06:18 PM How much did the pump cost you. I have the same problem. Where abouts from the pump is it leaking, cant this be fixed. Thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/58307-mystery-power-steering-leak-ba-xr6t-try-to-work-this-one-out/page/3/#findComment-896421 Share on other sites More sharing options...
bluesmuso Member 144 Member For: 17y 9m 9d Gender: Male Location: South Australia Posted 27/06/09 12:11 PM Author Share Posted 27/06/09 12:11 PM 2nd hand $110 from wreckers, it leaks from the seals and it it far easier to replace the entire pump than to replace seals which need special tools (ie puller to remove pulley wheel etc)Community work LOL Actually the council had workers smoothing off all of the rough joins in the street recently......all excpet the join which I hit. Link to comment https://www.fordxr6turbo.com/forum/topic/58307-mystery-power-steering-leak-ba-xr6t-try-to-work-this-one-out/page/3/#findComment-897412 Share on other sites More sharing options...
SAM80R Member 11 Member For: 16y 7m 20d Gender: Male Location: Newcastle Posted 16/02/10 02:17 AM Share Posted 16/02/10 02:17 AM Same problem here. Quoted about $250 for a new pump assembly... found some on old trusty EBAY for a lot less. Any one had experience with the pumps from ebay? Link to comment https://www.fordxr6turbo.com/forum/topic/58307-mystery-power-steering-leak-ba-xr6t-try-to-work-this-one-out/page/3/#findComment-982288 Share on other sites More sharing options...
