Zf Flaring When Cold
Evil F6
  • Member For: 19y 3d
I recently had the oil in the ZF changed to Castrol Transmax, and they also did the filter kit and things seemed fine for a while, but now the gearbox flares when cold. I'll be driving along at a steady 80km/h or so, and the revs keep changing between 1500 and 2100, back and forth. It seems fine when fully warmed up.
Now has any one else had issues since moving to transmax, as the gearbox was well behaved on the stock oil. I changed over as insurance now the car is making so much power power. It's only done 18000km.
  • Replies 61
  • Member For: 17y 8m 22d
your gearbox is low on oil and as the oil heats up it expands .... ive been told to make sure the oil is at 30 c when refilling for this reason by someone who does the services on a lot of zf gear
cheers trev
cheers trev
Hey trev, that makes sense. So if I return the car and they check it when cold they'll see the level is low. If this is the problem I'm not impressed as they said they've done quite a few and the fill procedure is well documented.
Thank you. :beerchug:
  • 3 weeks later...
  • New Member
  • Member For: 16y 2m 11d
Trev,
By using Transmax you oil you have more than likley stuffed your gearbox ($5 - $6000 exchange from ZF) and any remaining warranty that you might have had for the gearbox from Ford is now void. There is only one oil specied by ZF to use and only this oil should be used. There is only one company that makes the oil specified by ZF to use in their gear box. This is available through companies like Ford, Motor Spec etc. The first thing ZF will do when determining if it is a warranty will test the oil. Wrong oil, no warranty. Do not believe anyone that says otherwise. Remember they are not the ones paying for the repairs.
  • loitering with intent
  • Member For: 21y 4m 24d
add a CAI or zorst and your Fraud warranty is not worth a piece of Nanny goat sh*t in any case.
As for stuffing the gearbox ..... how ? By using the rip off Fraud fluids benefits the box how ?
and not just because Fraud said
  • New Member
Because the viscoity of the oil is different. This causes the clutchs to absorb the new oil and alters the characteristics of the friction material. As the computer is calibrated in micro seconds for shift quality to suit the correct oil, the use of other oil will cause slippage of the clutches(flaring), harsh shifting which can lead to transmission failure. Even after an expensive oil flush with the correct oil it cannot guarantee the reversal of the problem.
so was it the oil ?
Tunehouse said oil level is fine, but found metal filings in the oil and showing signs of wear:verysad:
It's only done 18K and I don't thrash it. Still waiting for full report.
What is going on with this?
