Zf Tuning...
Tucool
  • Replies 167
  • Member For: 19y 7m 26d
Increase shift pressure into 2nd to stop hitting the rev limitor in first gear when you have increased the power.
Improve longevity of the box by overall increasing shift pressures.
Typical things which have been done in the past to handle more power.
But I also see alot of broken input shafts. Considering we're already seeing twisted(and broken) input shafts with higher powered vehicles!
The ZF input shaft diameter is tiny, like something you'd see on a 4 cylinder barina.
The 4 speed auto has a input shaft diameter nearly double in size!!!
  • Member For: 19y 4m 18d
Is there a way of using the FG injector cut strategy on high load shifts on BF series auto's?
To me this is going to be of greatest value in reducing fatigue failures and reduce clutch wear/degradation.
  • Member For: 15y 6m 26d
Yes you can, I did it on a G6E some time ago, its sound cool too as it missfires on shift, it's a catch 22. If you want to ET fast you need to have the shift occur fast with no torque reduction. The ECU employs a number of torque reduction strategies that can be adjusted such as throttle, timing and fuel cut. The manufacturer uses them in order of the severity of reduction required. Timing first as it is fast reacting.
Cheers
Joel
The FG injector cut is done in the PCM, nothing to do with the ZF..
I've turned it off on the FG's, as well as enabled it on BA/BF's for laughs..
There is 4 torque control methods used in the Ford strategies.
Spark Retard
Air/Fuel adjustment
Injector cut
Electronic throttle
Large torque reductions are done with the following priority -> Injector Cut, Air/Fuel adjustment, and then Spark retard.
Each one of these 4 methods can be adjusted, as well as enabled or disabled individually.
**None of this is to be re-published without my permission**
