TURBO4LT Member 1,533 Member For: 21y 4m 21d Gender: Male Location: NSW Posted 04/06/09 06:32 AM Author Share Posted 04/06/09 06:32 AM Thanks Link to comment Share on other sites More sharing options...
Guest EGOXRT Guests Posted 04/06/09 08:08 AM Share Posted 04/06/09 08:08 AM He is right, they are still to soft.. Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 4m 21d Gender: Male Location: NSW Posted 04/06/09 08:32 AM Author Share Posted 04/06/09 08:32 AM those spring rates are still soft....the bilstein is valved to work with stock to +20% spring rates.I have 670/436 in mine and its fine with the right dampers.He is right, they are still to soft..What would you guys recomend? Link to comment Share on other sites More sharing options...
trevs Member 781 Member For: 17y 8m 18d Gender: Male Location: balmain Posted 04/06/09 09:18 AM Share Posted 04/06/09 09:18 AM ive got 520/310 kings and bilstein shocks in my in car and to be honest I feel its still way to softive still got standard sway bars fitted untill the weekend when im gonna change the lower control arm bushes front and rear and also my ball joints have a bit of play in them so ill change all them over plus fitting 27mm front ,22mm rear sway bars in short id either go bigger spring rates ...... if I could find some ? anyone know who sells some or coilovers if I was to do it again ill post up how much better the car feels after doing all these things some time early next week trev Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 4m 21d Gender: Male Location: NSW Posted 04/06/09 09:30 AM Author Share Posted 04/06/09 09:30 AM ive got 520/310 kings and bilstein shocks in my in car and to be honest I feel its still way to softive still got standard sway bars fitted untill the weekend when im gonna change the lower control arm bushes front and rear and also my ball joints have a bit of play in them so ill change all them over plus fitting 27mm front ,22mm rear sway bars in short id either go bigger spring rates ...... if I could find some ? anyone know who sells some or coilovers if I was to do it again ill post up how much better the car feels after doing all these things some time early next week trevThanks, that's good feedback. Link to comment Share on other sites More sharing options...
F6BF Member 438 Member For: 19y 27d Location: Sydney Posted 04/06/09 09:34 AM Share Posted 04/06/09 09:34 AM Frank I am running that combo with whiteline stabilizers, just right imo for daily driverBig step up from stock suspension Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 4m 21d Gender: Male Location: NSW Posted 04/06/09 09:37 AM Author Share Posted 04/06/09 09:37 AM Thanks, I was going to get the Teins but wasnt totally happy with the feel for a daily driver and have used Bilsteins before with good results. Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 7m 19d Gender: Male Location: Sydney NSW Posted 04/06/09 12:50 PM Share Posted 04/06/09 12:50 PM I had those springs in my BA, but with stock inserts/shocks... I found them to be a great spring rate for street and track, reduced the front end dive under brakes and body roll was greatly reduced... well worth using.I tried to get them for the FG a few weeks ago, but they dont make them yet for the front Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 4m 21d Gender: Male Location: NSW Posted 04/06/09 09:35 PM Author Share Posted 04/06/09 09:35 PM Thanks, that's what I mainly want reduced nose diving and better body roll controll without going to harsh for the street. Link to comment Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 21y 3m 6d Gender: Male Location: Sydney Posted 05/06/09 12:06 AM Share Posted 05/06/09 12:06 AM ive got 520/310 kings and bilstein shocks in my in car and to be honest I feel its still way to softive still got standard sway bars fitted untill the weekend when im gonna change the lower control arm bushes front and rear and also my ball joints have a bit of play in them so ill change all them over plus fitting 27mm front ,22mm rear sway bars in short id either go bigger spring rates ...... if I could find some ? anyone know who sells some or coilovers if I was to do it again ill post up how much better the car feels after doing all these things some time early next week trevTo run big rates you really need dampers to match. The Tein SS Performance spec coilovers run 670/436, the street spec coilover runs about 580 front and equivalent rear. I have the former and can tell you body control is MUCH improved over stock. The damping is fine for the street. However, IMHO even 670/436 is less than ideal for SERIOUS use on the circuit. The front rates are still not enough to stop front lateral weight transfer (ie. falling over outside front wheel) 1200/850 is the rate used on "Howsee"s car which has custom valved Zeal Super Function R coilovers, and the word is the thing is excellent on the circuit. mind you this costs about $8k. Other alternatives to run heavier rates than the Teins are DMS 50MM which will allow you to select rates these are like $4-5k I think , and I am sure there is a Custom Bilstein Motorsport solution as well. However, for the money at 2.2-2.5k the Tein SS "performance" spec is as good as you will get for street/track dual purpose use imho of course. Link to comment Share on other sites More sharing options...
