PSI40T Member 448 Member For: 18y 2m 12d Posted 03/06/09 01:11 AM Share Posted 03/06/09 01:11 AM well im wanting to replace my black lower window trim peices to the chrome versions off a g6e... does any one know how these are removed? do they just pull off, held in by clips?? Link to comment https://www.fordxr6turbo.com/forum/topic/58166-removing-window-trim-on-fg/ Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 12d Gender: Male Location: Earth Posted 03/06/09 06:39 AM Share Posted 03/06/09 06:39 AM Basically yep. Just work your way from one edge to the other. Link to comment https://www.fordxr6turbo.com/forum/topic/58166-removing-window-trim-on-fg/#findComment-885154 Share on other sites More sharing options...
bunna Donating Members 813 Member For: 18y 8m 6d Posted 04/06/09 10:13 AM Share Posted 04/06/09 10:13 AM You mean the belt line mould yeah? Just clips - start at the rear edges. Make sure you put a piece felt tape across the section that slides under the mirror (your old ones *should* have it, dunno your build date). Link to comment https://www.fordxr6turbo.com/forum/topic/58166-removing-window-trim-on-fg/#findComment-885910 Share on other sites More sharing options...
PSI40T Member 448 Member For: 18y 2m 12d Posted 04/06/09 11:17 PM Author Share Posted 04/06/09 11:17 PM (edited) im buying the chrome mouldings new from ford so they should come with that felt tape im guessing?? not to sure what u mean ? Edited 04/06/09 11:18 PM by LT5PLA Link to comment https://www.fordxr6turbo.com/forum/topic/58166-removing-window-trim-on-fg/#findComment-886191 Share on other sites More sharing options...
PSI40T Member 448 Member For: 18y 2m 12d Posted 05/06/09 02:50 AM Author Share Posted 05/06/09 02:50 AM well picked up the trim today, although I wont be able to change it over till Tuesday now since they had wrongly stocked a black piece instead of the chrome , so they needed to order it in .. anyways, the rear seems like it pops off no problems but the front trim seems to run under the side mirror? do I need to remove the side mirror to remove the front lower trim... Link to comment https://www.fordxr6turbo.com/forum/topic/58166-removing-window-trim-on-fg/#findComment-886269 Share on other sites More sharing options...
PSI40T Member 448 Member For: 18y 2m 12d Posted 09/06/09 07:59 AM Author Share Posted 09/06/09 07:59 AM got em on.. figured it out in the end.... all good... thanks for everyones help... Link to comment https://www.fordxr6turbo.com/forum/topic/58166-removing-window-trim-on-fg/#findComment-888111 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 12d Gender: Male Location: Earth Posted 09/06/09 08:59 AM Share Posted 09/06/09 08:59 AM Pics? Link to comment https://www.fordxr6turbo.com/forum/topic/58166-removing-window-trim-on-fg/#findComment-888174 Share on other sites More sharing options...
PSI40T Member 448 Member For: 18y 2m 12d Posted 10/06/09 07:19 AM Author Share Posted 10/06/09 07:19 AM ill have pics up tomorrow and also of my retrimmed interior by doyles "phantom im still chasing the dyno graph with the afr's etc... im just going to have to go past and get it off them..." Link to comment https://www.fordxr6turbo.com/forum/topic/58166-removing-window-trim-on-fg/#findComment-888679 Share on other sites More sharing options...
JAKEE Member 5 Member For: 15y 21d Posted 26/10/10 05:41 AM Share Posted 26/10/10 05:41 AM how much did the chrome trim form ford set you back? how'd you go about talking off the black trim? Link to comment https://www.fordxr6turbo.com/forum/topic/58166-removing-window-trim-on-fg/#findComment-1050610 Share on other sites More sharing options...
sxckevo Member 3 Member For: 15y 6m 27d Posted 25/11/10 11:27 AM Share Posted 25/11/10 11:27 AM yeh id like to know the same thing. any help would be appreciated cheers kev Link to comment https://www.fordxr6turbo.com/forum/topic/58166-removing-window-trim-on-fg/#findComment-1058469 Share on other sites More sharing options...
