KAL_SPL Member 144 Member For: 21y 2m 8d Location: Kalgoorlie WA Posted 24/07/09 11:29 AM Author Share Posted 24/07/09 11:29 AM Prob around 10K swapped hands , the replacement on the tray alone would be 10K fitted , we havnt tallied up the cabs system as of yet. Link to comment https://www.fordxr6turbo.com/forum/topic/58081-just-cut-a-hole-and-move-the-deck-he-said/page/15/#findComment-911496 Share on other sites More sharing options...
KAL_SPL Member 144 Member For: 21y 2m 8d Location: Kalgoorlie WA Posted 31/07/09 04:03 AM Author Share Posted 31/07/09 04:03 AM More polishing , will have completed this weekend and running. Link to comment https://www.fordxr6turbo.com/forum/topic/58081-just-cut-a-hole-and-move-the-deck-he-said/page/15/#findComment-914698 Share on other sites More sharing options...
KAL_SPL Member 144 Member For: 21y 2m 8d Location: Kalgoorlie WA Posted 01/08/09 09:28 AM Author Share Posted 01/08/09 09:28 AM All polished up , box is now covered and ports fitted , just need to weld it all together and slide it in then box can go back in for the final time !Top panel will be black suade aswell which will be covered when Im happy with the port fitment , atm its not quite 100% on what I want it , the machining is slightly out from what I should have given him measurements for :( Link to comment https://www.fordxr6turbo.com/forum/topic/58081-just-cut-a-hole-and-move-the-deck-he-said/page/15/#findComment-915339 Share on other sites More sharing options...
alpha Member 266 Member For: 18y 3m 8d Gender: Male Location: Perth Posted 02/08/09 11:42 AM Share Posted 02/08/09 11:42 AM lookin gooood :smilelove: Link to comment https://www.fordxr6turbo.com/forum/topic/58081-just-cut-a-hole-and-move-the-deck-he-said/page/15/#findComment-915775 Share on other sites More sharing options...
Flukey Seriously Flukey Member Donating Members 4,354 Member For: 21y 2m 22d Gender: Male Location: Melbourne Posted 02/08/09 12:06 PM Share Posted 02/08/09 12:06 PM Impressive. Link to comment https://www.fordxr6turbo.com/forum/topic/58081-just-cut-a-hole-and-move-the-deck-he-said/page/15/#findComment-915785 Share on other sites More sharing options...
KAL_SPL Member 144 Member For: 21y 2m 8d Location: Kalgoorlie WA Posted 02/08/09 02:03 PM Author Share Posted 02/08/09 02:03 PM All finished , bloody loud to , the best part is everything works and sh*t , cant be happier Link to comment https://www.fordxr6turbo.com/forum/topic/58081-just-cut-a-hole-and-move-the-deck-he-said/page/15/#findComment-915824 Share on other sites More sharing options...
robbo k Member 414 Member For: 17y 2m 5d Location: Wollongong Posted 02/08/09 11:20 PM Share Posted 02/08/09 11:20 PM did u end up replacing the poineer subs in the back with something else? Link to comment https://www.fordxr6turbo.com/forum/topic/58081-just-cut-a-hole-and-move-the-deck-he-said/page/15/#findComment-915879 Share on other sites More sharing options...
KAL_SPL Member 144 Member For: 21y 2m 8d Location: Kalgoorlie WA Posted 03/08/09 12:19 AM Author Share Posted 03/08/09 12:19 AM Nope just rewired them to a 4ohm load instead of 1 , the amp is only rated down to 2 ohm hence why it was cutting out.@ 4ohm it still makes 1000rms and let me tell you theres still ample power to make it run perfectly for our application , the plus side is that current draw is ALOW lower so batteries last longer which given the intended use is the base scenario The subs in the cab are dual 1.5s so I was a bit worried bout getting enough power before it cut out but given the 20mm flex on the windscreen with flat batteries I would say its not a concern.If we do get good numbers as it is now I will swap the amp for my D3 just to use for an SPL comp , that's capable of 3000rms @ 0.25ohm.If that's still not enough I will add the 2nd D3 see if I cant crack the windscreen Link to comment https://www.fordxr6turbo.com/forum/topic/58081-just-cut-a-hole-and-move-the-deck-he-said/page/15/#findComment-915891 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 12d Gender: Male Location: Adelaide Posted 03/08/09 01:14 AM Share Posted 03/08/09 01:14 AM sick as man how many db she puttin out? Link to comment https://www.fordxr6turbo.com/forum/topic/58081-just-cut-a-hole-and-move-the-deck-he-said/page/15/#findComment-915904 Share on other sites More sharing options...
KAL_SPL Member 144 Member For: 21y 2m 8d Location: Kalgoorlie WA Posted 03/08/09 01:46 AM Author Share Posted 03/08/09 01:46 AM Haha nfi at the moment , closest meter is 600km away.Educated guess is close to 145 , how ever it sounds closer to 150 by ear , different spots in the car have different pressure.Will find out at Powercruise unless I get a meter before hand. Link to comment https://www.fordxr6turbo.com/forum/topic/58081-just-cut-a-hole-and-move-the-deck-he-said/page/15/#findComment-915910 Share on other sites More sharing options...
