  • Replies 167
  • Member For: 21y 2m 6d
Box and floor trimmed , subs wired in and all running , just waiting on 2 more batteries and the inverter , still have to get plate made for floor and trim panels for top and back of the box , we ran out of red suade
  • Member For: 19y 1m 3d
Fark me...you may be a Expensive Daewoo boy, but you know what you're doing come carpenting time (and that's not all of it).
Good going, Kal, looking very good - overkill for me when it comes to audio-systems, but then I'm sure that's the same with me when it comes to carputers - lol.
To everyone else here: An engine doesn't know (or care)(about) the badge on it's tappet-covers......
Depends what you do to the inside is what ultimately matters .....[/stir-mode off]
Thanks mate appreciate it :)
Its overkill yes but when you consider this is being built as promotional vehicle for my business and it has literally cost us next to nothing (gear included) its about the biggest business card you can get :)
The floor piece has been cut and will be powder coated tomorrow , more trim has been ordered and by the end of the weekend I should have the tray almost complete.
Had a few construction issues with the facia but its back on track now.
The subs are dual 2s , each is seriesed then all 4 parralelled to make a 1ohm load , originally we were going to use a D3 earthquake which is good for over 3000rms @ 1/4ohm or 2000rms @ 1ohm but we kind of acquired this Pioneer mono which is only rated down to 2ohm & 1500rms.
Have already found the limits and its dropping out at high volume , we will have to change all 4 subs over to dual 4s at some stage.
Im going to rewire the subs to 4ohm load and see if its enough to run sufficiently.
To run the DDs at comps Im going to need more power than 1500rms so still not decided what to do there.
Might just swap the monos over if theres an SPL comp on , the DDs are dual 1.5s , D3 burps @ .375 ohm oh yeah baby ! 350amp+ current draw :3gears:
Tray is now 95% complete , just needs the 2nd cushion trimmed and struts mounted.
Floor came up sweet and the cushions look good and are quite comfortable ...
Still waiting on the DVD head unit and inverter to get the picture going.
Now its onto the cab , half way yay ...
