IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 22d Gender: Male Location: OZ Posted 29/07/09 01:16 AM Share Posted 29/07/09 01:16 AM There's no reason ETM couldn't fit an external gate to the exhaust turbine housing. If it's an Fg F6 turbo, take it to turbotech and demand that they bore it out as the hole is still smaller than a ported BA hausing. They advised against it with my FG housing but just take it there and say you want it done! Link to comment https://www.fordxr6turbo.com/forum/topic/57877-overboost/page/2/#findComment-913667 Share on other sites More sharing options...
Ricky N Member 93 Member For: 16y 1m 7d Gender: Male Location: QLD Posted 29/07/09 08:10 AM Share Posted 29/07/09 08:10 AM I suggest having the wastegate bored but more impotently the hole ported to bring angle of the gases to the flap better. Link to comment https://www.fordxr6turbo.com/forum/topic/57877-overboost/page/2/#findComment-913863 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 3d Gender: Male Location: @ my laptop Posted 29/07/09 09:16 AM Share Posted 29/07/09 09:16 AM A port job should include both of those, not just make the hole larger Link to comment https://www.fordxr6turbo.com/forum/topic/57877-overboost/page/2/#findComment-913910 Share on other sites More sharing options...
Ricky N Member 93 Member For: 16y 1m 7d Gender: Male Location: QLD Posted 29/07/09 09:25 AM Share Posted 29/07/09 09:25 AM ratter said: A port job should include both of those, not just make the hole larger Agreed Link to comment https://www.fordxr6turbo.com/forum/topic/57877-overboost/page/2/#findComment-913919 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 4m 6d Gender: Male Location: Sydney Posted 29/07/09 09:30 AM Share Posted 29/07/09 09:30 AM Please explain what is happening?What is the desired boost?Is it overboosting. If so, when?Do you have surging and irregular acceleration?Have you run a static test on the wastegate to see what pressure the wastegate opens?In cases a softer spring IS a better solution. In my experience increasing spring pressure closer to desired boost level is more likely to give you problem controlling bost. In many cases guys just increase spring pressure to reduce waste creep because it gives tuners more money in their pocket as well as a conventionally accepted solution, but boost control is more difficult. The closer you are with desired boost to base actuator spring opening the more likely your are to have boost control problems, in my experience.Brian Link to comment https://www.fordxr6turbo.com/forum/topic/57877-overboost/page/2/#findComment-913924 Share on other sites More sharing options...
djkice Boost Addict Member 1,273 Member For: 16y 9m 8d Gender: Male Location: Perth, W.A. Posted 06/08/09 03:58 PM Share Posted 06/08/09 03:58 PM This is quite strange actually.I have same setup but my car has the CAI on... makes a few KW more.I have the FG XR6T with upgraded compressor wheel to same as FG F6, ported(I hope) and 12psi actuator.Boost control seems fine though Link to comment https://www.fordxr6turbo.com/forum/topic/57877-overboost/page/2/#findComment-917655 Share on other sites More sharing options...
gravelrash Member 211 Member For: 22y 3m 28d Gender: Male Location: Dalby, QLD Posted 06/08/09 08:48 PM Share Posted 06/08/09 08:48 PM IH8TOADS said: There's no reason ETM couldn't fit an external gate to the exhaust turbine housing. If it's an Fg F6 turbo, take it to turbotech and demand that they bore it out as the hole is still smaller than a ported BA hausing. They advised against it with my FG housing but just take it there and say you want it done!I probably wouldnt "demand" things to be done. ask nicely and you will go alot further. Link to comment https://www.fordxr6turbo.com/forum/topic/57877-overboost/page/2/#findComment-917668 Share on other sites More sharing options...
djkice Boost Addict Member 1,273 Member For: 16y 9m 8d Gender: Male Location: Perth, W.A. Posted 30/08/09 01:09 PM Share Posted 30/08/09 01:09 PM I seem to be experiancing this problem now... after adding the more efficiant cooler.My WG is ported out to 38mm and has the larger flapper. Have been reading around on the internet which leaves me curious if it may have something to do with the dump pipe, being somewhat narrow the way the FG turbo is mounted. Attached a photo of dump pipe Link to comment https://www.fordxr6turbo.com/forum/topic/57877-overboost/page/2/#findComment-927313 Share on other sites More sharing options...
XR64LT Donating Members 678 Member For: 17y 3m 22d Gender: Male Location: sydney Posted 20/09/09 01:25 AM Share Posted 20/09/09 01:25 AM do you need to get your car retuned once you install a 12psi actuator?? Link to comment https://www.fordxr6turbo.com/forum/topic/57877-overboost/page/2/#findComment-934688 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 3d Gender: Male Location: @ my laptop Posted 20/09/09 01:26 AM Share Posted 20/09/09 01:26 AM yes you do. Link to comment https://www.fordxr6turbo.com/forum/topic/57877-overboost/page/2/#findComment-934689 Share on other sites More sharing options...
