phoonme Member 8 Member For: 15y 11m 8d Posted 22/05/09 07:13 AM Share Posted 22/05/09 07:13 AM (edited) ok guys im a newbie and have been searching the forum all day for little tips ect, from what oil to use to bov's ect.I own a 03 xr6 turbo with 103000 on the clock and have been loving the car. got the diff rebuilt 2000kms ago new 330mm front rotors and pads rah rah rah. had the manifold studs come to loose 3 times but have fixed it using cone nuts :-DI use to own a 95 futura 5 spd and when the clutch would grip at the end of the stroke I adjusted it and it was fine being the cable clutch. sorry to sound dumb but can u adjust the hydrolic clutch at all?? ie put more of less fluid in or anything as the gripping point is at the end of the stroke and its annoying. car has a new clutch in it as of 4 months ago. I look forward and keen to learning more about my car on the forum some people really no there stuff :-)lincoln Edited 22/05/09 07:15 AM by phoonme Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 1m 4d Gender: Male Location: SW Sydney Posted 22/05/09 07:57 AM Share Posted 22/05/09 07:57 AM As far as I know you can't adjust them being hydraulic, however you may need to bleed the clutch to get it correct. Since the clutch has been changed you may want to try that to cancel out some possibilties. Another thing to look at could be the Slave cylinder, the genuine ones are plastic and have a habit of getting lazy. Link to comment Share on other sites More sharing options...
phoonme Member 8 Member For: 15y 11m 8d Posted 23/05/09 12:48 AM Author Share Posted 23/05/09 12:48 AM just asking a dumb question. just wondering how to do that. checked the hydro fluid tank and it was on min. so I topped it up but still no change. advice please?? Link to comment Share on other sites More sharing options...
jacob_xr6turbo Donating Members 433 Member For: 17y 6m Location: Richmond, Melbourne Posted 26/05/09 12:17 PM Share Posted 26/05/09 12:17 PM bleeding the clutch requires you to release a bleed nipple on the bellhousing under the car.. Then gravity will bleed the fluid from the resevoir (with the cap off and someone there making sure the fluid is always topped up) and the clutch will be bled.Post up in Mal wood's section of this forum for more information, and he might have some other tips/hints on how to adjust the clutch to suit.. Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 10m 14d Gender: Male Location: Victoria Posted 27/05/09 07:31 AM Share Posted 27/05/09 07:31 AM Not in these cars...Just pump the crap out of the pedal and it bleeds the air out.The nipple is there when you want to change the fluid.These clutches self adjust. Link to comment Share on other sites More sharing options...
