  • Member For: 19y 2m 4d
I just got a aftermarket transmission pan installed on my auto today which should cool the transmission fluid more and strengthen the case up a bit. It even has a drain plug! It takes the standard gasket and filter.
post-8558-1242894109_thumb.jpgpost-8558-1242894155_thumb.jpgpost-8558-1242894188_thumb.jpg
https://www.fordxr6turbo.com/forum/topic/57843-transmission-pan/
  • 4 weeks later...
  • Member For: 19y 6m 4d
Is that a standard oil capacity pan? If it is one with a deeper sump for a bit of extra volume would of been better
True Lolly,but a deeper pan also holds more fluid as well as more external surface area both aiding in better heat transfer.It also will allow for filter/pickup extension deeper in the pan for those hi KW hard launch vehicles that could previously momentarily run dry after the initial launch.Imo
