Plenum Induction Noise - Unusual?
  • Member For: 19y 7m 22d
I have a very strange noise under the bonnet and I can't diagnose what it is, either can a tuner, either can ford.......so I'm turning to the forums!
I have recently had Nizpro valve springs fitted, plazmaman plenum, and had the turbo mod done. I have barely driven the car, but at idle when I give it a very sharp stab at the throttle I get the 'shhhh' type noise for a split second before the engine revs up. It's quite auditable and annoying. If I rev the engine up slowly you can't hear the noise.
To me it sounds like it's coming from under the rocker cover but ford just rang me and assures me it's induction noise. I had them do a cylinder leakage test and everything is at 95%+. I have re-fitted the plenum...checked for leaks and still no answers.
Any help would be appreciated. Cheers!
  • Replies 24
  • Member For: 18y 5m 6d
My Fiesta does that, its just intake noise. As the fiesta has a plastic manifold its more audible, and as you have gone from a cast thick manifold to a thin manifold you can now hear it easier... You have to live with it...
  • Member For: 16y 9m 19d
did you change the metal gasket when you put the plenum on. I didnt & it leaked making the same sought noise but once I used some gasket sealent & a new gasket all solved.
Thanks guys. Boost leak was my initial thoughts but I had used a brand new gasket and also silicon sealant. I had a well regarded tuner look at it and he also had a high hp car with the same plenum there and it didn't make the same noise as mine (only difference between the plenum was that mine was black!). The tuner reckoned it wasn't a boost leak. I re-fitted the plenum without the gasket (just sealant) and the noise is still there. Checked hoses etc a number of times.
It doesn't sound like air is rushing through the plenum, unless it is air gushing in as the TB cracks open? It's quite loud and the fact that it only happens on my car (and not others with the same plenum) is quite bizarre! It's got everyone stumped, so I may have to get it tuned and then see what happens on the dyno?
Edited by IH8TOADS
  • Dr. Speed
  • Member For: 17y 7m 1d
  • Location: The land of Politicians, Public Servants, Porno & Pyrotechnics
you can definately hear the air rushing through a fabricated plenum
:blink:
It's definitely the plenum mate. Mine makes the exact same noise, it’s just the air rushing in as the TB opens. Stick your ear against the plenum and give it a little rev… I actually thought it was a problem too when I first heard it.
I don't mind the sound, and it's nothing to worry about. Don't think you will be able to do anything about it anyway!
Interesting! exarhsix is your processor code A3YB? You have very similar mods to me so if it is indeed induction noise then a solution maybe in the throttle settings?
