  • Member For: 15y 11m 16d
Sweet glad it was nothing major.
on a side not got any pics mate, ive always been a fan of the force 6 :spoton:
Yeah man as soon as I get it off the hoist I'll take some snaps.
  • Member For: 17y 3m 1d
We have an FG xr6t at work at the moment that has done the same thing. Top bit of timing chain guide,plastic buffer snapped off and ended up going between chain and crank sprocket. Caused timing to jump 2 teeth at the crank and was making some death noises. We corrected the timing and retested comps and found low comp mainly on no1. Air leak tested that cylinder and it seems to have bent inlet valves as its just pumping air out the throttle body. Apparantely this is a common thing but was the first one I had seen. Goodluck with it.
  • It's not a MKI!
  • Member For: 16y 10m 12d
Ended up being a timing guard had broken off and ended up caught between the timing chain and oil pump. Chain and pump okay so while the engine is out I'll be replacing oil pump gears with billets. Cheers for the feedback.
Glad you found something, however it doesn't explain your 'unburnt fuel or oil spitting from rear exhaust pipe'??
Heres a couple I took on my phone not best quality picture.
  • Member For: 17y 1m 29d
If the cam timing had jumped it would be very likely to be pumping raw fuel out the exhaust, hope the cat is ok.
  • Member For: 19y 4m 14d
I can still see a compression test comming up with some unhappy figures,hope im wrong though.Good luck with it and keep us posted.By the way that's a nice looking ride.
