Problem With Lowering Blocks
jasol
  • Member For: 16y 10m 22d
No worries mate, hope that's all it is. If you still have concerns take it to pedders or a suspension specialist to check that everything is lined up correctly, if not it shouldnt be much of a drama to reallign it. JMan had it done a little while ago on his ute after Ford incorrectly fitted his new diff. Details here.
:hay:
  • Member For: 16y 2d
cheers for that I had a read, I cant see how ford could incorectly fit the diff so 1 rim sits in and the other out as the diff locates itself onto the leaf springs on the lil round hump thingos and it shouldnt move then the shock is just bolted to a small platform which bolts the the U bolts. its a strange one
