stevet Member 85 Member For: 17y 2m 27d Posted 14/05/09 05:19 AM Share Posted 14/05/09 05:19 AM Hey guys if any of you have been paying close attention you may recall recently I have had my fair share of issues getting more power out of my BA XR6T. At the moment I have a stock motor with a HDi Intercooler kit. It has been tuned to make about 225rwkw (which I thought was dissapointing) but at this boost level (about 10psi I think) it also has a surging issue. If I take off from standstill the car seems fine, but for example I use tiptronic and engage third at maybe 80km the car seems to have a surging problem where it cycles between boosting and then not. It does it really any time you load the engine and make it work from lower rpm at speed. My tuner has checked everything and the only thing he can suggest is put the stock cooler back on to see if it makes a difference. Which is the last thing I want to do as its a bugger of a job and may all be in vain as it sounds like a longshot to me. Any ideas?! Link to comment https://www.fordxr6turbo.com/forum/topic/57639-is-it-my-intercooler/ Share on other sites More sharing options...
exarsixturbo Dr. Speed Member 784 Member For: 17y 11m 7d Gender: Male Location: The land of Politicians, Public Servants, Porno & Pyrotechnics Posted 14/05/09 06:49 AM Share Posted 14/05/09 06:49 AM Doesn't sound like a cooler problem that's for sure!If the cooler wasn't that good it would just make the intake temps slightly higher than a "good" one. This could be the cause for the low power figure but it wouldn't be the cause of the surging.Surging is more likely to be fuel (or tune) related. I don't know your mods, but I would be looking at injectors and/or a pump before you go swapping the cooler over. Also make sure that all the vacuum lines and sensors are connected properly from when your cooler was fitted. Link to comment https://www.fordxr6turbo.com/forum/topic/57639-is-it-my-intercooler/#findComment-876300 Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 18y 2m 10d Gender: Male Location: central coast Posted 14/05/09 07:04 AM Share Posted 14/05/09 07:04 AM if you have a 4spd auto ,they will do this if your tuner hasn't had a lot of exp with themmine is an 06/03 model and it's got something to do with the process codes in the ecu and if you have ones like mine , they gave an experienced tuner about 2 days of head aches to sort out Link to comment https://www.fordxr6turbo.com/forum/topic/57639-is-it-my-intercooler/#findComment-876306 Share on other sites More sharing options...
dvsboy Member 11 Member For: 17y 24d Posted 14/05/09 07:18 AM Share Posted 14/05/09 07:18 AM I`ve got the excact same problem on my BA, but I can tell you it is not the intercooler. I had mine flash tuned before I installed my Hdi intercooler and it was surging the same way you have described. What I`ve actully noticed is that it has got a bit better since I put the cooler on. Link to comment https://www.fordxr6turbo.com/forum/topic/57639-is-it-my-intercooler/#findComment-876317 Share on other sites More sharing options...
stevet Member 85 Member For: 17y 2m 27d Posted 14/05/09 07:28 AM Author Share Posted 14/05/09 07:28 AM Thanks for the info guys. Yeah he tells me injectors are working well within their capacity, all the coil packs have been checked and are satisfactory. Apparently there was a fault code with the throttle body at one stage dont know if that has been sorted. Everything has been checked and I think he is just clutching at straws suggesting it could possibly be the new cooler! I know you guys advise to go elsewhere but at this stage there isnt really an elsewhere and once you go so far with a tuner its not so easy to change at least until current issues are resolved. our06t I'd be really interested if you knew anything more about these 'process codes'. Im sure this is a tuning issue even though he says there is a slight and very hard to detect surge on the standard tune. Link to comment https://www.fordxr6turbo.com/forum/topic/57639-is-it-my-intercooler/#findComment-876327 Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 18y 2m 10d Gender: Male Location: central coast Posted 14/05/09 07:35 AM Share Posted 14/05/09 07:35 AM yeh I can send ya a pm ,with a few suggestions Link to comment https://www.fordxr6turbo.com/forum/topic/57639-is-it-my-intercooler/#findComment-876333 Share on other sites More sharing options...
stevet Member 85 Member For: 17y 2m 27d Posted 14/05/09 07:40 AM Author Share Posted 14/05/09 07:40 AM If you could that would be fantastic mate Link to comment https://www.fordxr6turbo.com/forum/topic/57639-is-it-my-intercooler/#findComment-876336 Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 5m 20d Gender: Male Posted 14/05/09 08:37 AM Share Posted 14/05/09 08:37 AM sounds exactly like coil symptoms. if not, could be the torque settings in the box. id definately be tryin new coils. how old/klms is the car ? Link to comment https://www.fordxr6turbo.com/forum/topic/57639-is-it-my-intercooler/#findComment-876383 Share on other sites More sharing options...
stevet Member 85 Member For: 17y 2m 27d Posted 14/05/09 09:33 AM Author Share Posted 14/05/09 09:33 AM thanks mic. coils all checked ok apparently. Im starting to think its this tourqe control settings which our06t also suggested. The tuners are all scratching their heads cos a BF they tuned was sweet as, which would make sense seeing as its a totally different trans and capable of more load. Link to comment https://www.fordxr6turbo.com/forum/topic/57639-is-it-my-intercooler/#findComment-876405 Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 17y 4m 5d Gender: Male Location: Blacktown! Posted 14/05/09 11:05 AM Share Posted 14/05/09 11:05 AM Yeah Ive got a surging issue also. Over the past 6 months I have changed valve springs, Coils, spark plugs (twice), fuel filter, got different fuel from several servo's, been back to a reputable(forum sponsor) tuner 3 times and they claim to have solved it opn the dyno but havent. Only thing that did fix it for a short time was getting new coils. Fixed it for a week, but then again it could have been all in my head. Im thinking its my gearbox but only in 2nd gear(ofcourse I have no basis on that just that it happens only in 2nd gear from lower rpm WOT. After tax time Im going for second round of power mods and a new tuner, hopefully may solve the issueGood luck hunting it down and let us know if you figure it out Link to comment https://www.fordxr6turbo.com/forum/topic/57639-is-it-my-intercooler/#findComment-876551 Share on other sites More sharing options...
