ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 3m 23d Gender: Male Location: Sydney Posted 13/05/09 09:14 AM Share Posted 13/05/09 09:14 AM Clint I merged your topic with the current HDI discussion. Link to comment https://www.fordxr6turbo.com/forum/topic/57609-hdi-hybrid-intercooler/page/2/#findComment-875938 Share on other sites More sharing options...
clint-xrt Member 41 Member For: 16y 1m 1d Gender: Male Posted 13/05/09 09:23 AM Share Posted 13/05/09 09:23 AM thanks mate just new to this site Link to comment https://www.fordxr6turbo.com/forum/topic/57609-hdi-hybrid-intercooler/page/2/#findComment-875945 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 4m 23d Gender: Male Location: QLD Posted 13/05/09 09:46 AM Share Posted 13/05/09 09:46 AM I'm running the GT Series 600x300x75 on my BA XR 6 and in comparisment I went to the drags with a friend who is runninga PW cooler but near identical everything else in a BF F6.Mine when a few tenths quicker. I also had to short shift 3rd as it started to ping and got back on it steadily in 4th.My car is tune by myself the other was tuned by a reputable shop and said to have 380rwkw.I am pretty happy with its performance.With my cooler it didn't come as a kit and I fitted it up higher enough so I can still get the under tray on.To do so I had to remove some material at the front of the chassis rails so the hoses could fit.A better option would be to have the outlets cut and welded at a angle as per other big coolers to fit the falcon.Well worth the money. Link to comment https://www.fordxr6turbo.com/forum/topic/57609-hdi-hybrid-intercooler/page/2/#findComment-875963 Share on other sites More sharing options...
jasol Member 571 Member For: 16y 4m 8d Location: adelaide Posted 13/05/09 09:49 AM Share Posted 13/05/09 09:49 AM pube does the over the radiator intake still fit?? did you have to modify/cut anything? cheers mate Link to comment https://www.fordxr6turbo.com/forum/topic/57609-hdi-hybrid-intercooler/page/2/#findComment-875966 Share on other sites More sharing options...
Pube Member 159 Member For: 18y 23d Gender: Male Location: Sydney, NSW Posted 13/05/09 10:01 AM Share Posted 13/05/09 10:01 AM No the over radiator intake will not fit back on. One positive side, it has nice induction note, sucking hot air or not. I also have a second intake snorkle anyway. The radiator fan shroud needed a bit of a trim, not the fans themselves though not a big deal. Also as you can see, the cooler hangs a bit low. I trimmed the lower part of my bumper so the last row of the cooler hangs below. Might sound a bit nasty, but if you take your time cutting it, it will turn out neatly. The stone tray does not fit back on but it has not been an issue driving without it at all. The steel bumper reinforcement structure needs to be trimmed which is common for aftermarket intercoolers. Ya gotta remember, this cooler is 100mm thick. Also, the kit comes with some sh*t alloy angle pieces which hold the cooler in place. These broke within a week so I made some up myself easily out of steel. The cooler is solid now. Link to comment https://www.fordxr6turbo.com/forum/topic/57609-hdi-hybrid-intercooler/page/2/#findComment-875975 Share on other sites More sharing options...
xrsixty Member 4 Member For: 16y 3m 14d Posted 28/05/09 07:03 AM Share Posted 28/05/09 07:03 AM yeah, just installed this on my car. bit of a tight fit, cos its large, but definitely worth the money.the car has a flashtune to suit the cooler, so no complaints yet.those that question the height of the cooler, how tall do you want it to be as its sitting behind the bumper support and not getting airflow? you want the largest 'cooler volume open to available, cool airflow. Having done temperature testing on an intercooler before using thermocouples, I can attest that any area of intercooler obscured directly by panels or the like is nigh on useless. Link to comment https://www.fordxr6turbo.com/forum/topic/57609-hdi-hybrid-intercooler/page/2/#findComment-882418 Share on other sites More sharing options...
RSK Member 340 Member For: 17y 8m 23d Gender: Male Posted 28/05/09 01:42 PM Share Posted 28/05/09 01:42 PM Pube said: Definately needs a tune as my car overboosted easily before the tune. Heres some pics of the kit on my car for reference.Damn that sits way low for my liking . Surely it's no harder to fit then a rapid kit, as that needs cutting to fit too. Link to comment https://www.fordxr6turbo.com/forum/topic/57609-hdi-hybrid-intercooler/page/2/#findComment-882611 Share on other sites More sharing options...
Plugg3r Caring Understanding Northern Territorian Member 159 Member For: 16y 11m 2d Gender: Male Location: Darwin, NT Posted 01/06/09 04:09 AM Share Posted 01/06/09 04:09 AM Pube, so your saying if you wished so the cooler wouldnt of been under the lip? Link to comment https://www.fordxr6turbo.com/forum/topic/57609-hdi-hybrid-intercooler/page/2/#findComment-883910 Share on other sites More sharing options...
Pube Member 159 Member For: 18y 23d Gender: Male Location: Sydney, NSW Posted 01/06/09 06:42 AM Share Posted 01/06/09 06:42 AM Ideally, it would be better if the cooler sat a bit higher so you didnt have to mod the bottom of the bar and also retain the stone tray/guard. The less cutting the better! However, it turned out nicely in the end. I have ground off the two alloy bosses on the bottom of the cooler that are not used, it doesnt bottom out like it use to. Link to comment https://www.fordxr6turbo.com/forum/topic/57609-hdi-hybrid-intercooler/page/2/#findComment-883954 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 4m 23d Gender: Male Location: QLD Posted 01/06/09 09:19 AM Share Posted 01/06/09 09:19 AM I have fitted mine and the cooler sits high enough to still have the plastic stone tray fit.However I had to grind away metal from the front chassis rails to get it up high.If yo look there is excess metal past the spot welds & I remove it keeping the welds intact.So it doesn't remove any structural material.the only down side with mine is the fitting coming out of the condensor keeps itfrom being central. (Not the one you bend out of the way).Mine is the GT Series 600x300x75 cooler. Link to comment https://www.fordxr6turbo.com/forum/topic/57609-hdi-hybrid-intercooler/page/2/#findComment-884068 Share on other sites More sharing options...
