jojo munro Member 2 Member For: 15y 9m 8d Posted 12/05/09 06:45 AM Share Posted 12/05/09 06:45 AM Does anyone know how to replace/repair front passengers power Window? Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 13d Gender: Male Location: SW Sydney Posted 12/05/09 06:56 AM Share Posted 12/05/09 06:56 AM Umm, pull it out and put a new one back in? A little more info in your question may help us help you What is the problem and whatexactly are you trying to replace? A motor, a switch, the whole window? Link to comment Share on other sites More sharing options...
jojo munro Member 2 Member For: 15y 9m 8d Posted 12/05/09 07:04 AM Author Share Posted 12/05/09 07:04 AM yeah sorry,I tried to lower the window this morning and heard a snap. The window neither goes up or down when I press the button. The motor seems to be working but nothing is happening. Link to comment Share on other sites More sharing options...
dule Donating Members 1,180 Member For: 17y 10m 4d Gender: Male Location: Sydney Posted 12/05/09 07:09 AM Share Posted 12/05/09 07:09 AM Take the door trim off and see what's broken. Once you see what's broken you'll know how to replace it too. That's how I do things anyway. Link to comment Share on other sites More sharing options...
Skillpottie Donating Members 55 Member For: 16y 11m 30d Gender: Male Location: sunny welby Posted 12/05/09 09:03 AM Share Posted 12/05/09 09:03 AM Hipull the door trim offThen there is three nuts that hold the motor in which is near the speaker.You can then inspect by lowering motor down in the door if it is like mine [drivers side] was it will be mess of wire around the pully which is attacted to the motor you will know if it's stuffed.If this is the problem you will need a new one. Ford quoted around $200 got one for $101 posted from kingswood country 03 9532 5806 think that's their number.If you need to replace there are two clips that hold the window in the craddle that runs in the baily channel.Then four bolts that hold the baily channel in the door two up the top and two down the bottom.You will see how it all works when you get the trim off took me about 45mins to replace and put back together.Would post some pics but can'nt seem to do it.Hope that helps. Link to comment Share on other sites More sharing options...
