Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 18y 10m 12d Gender: Male Location: Bentleigh, Vic, Australia Posted 07/05/09 07:46 AM Share Posted 07/05/09 07:46 AM (edited) Hi guys.Heres the list of mods for my car...CES Exhaust mated to a 5" Balistic Catv3 Rapid Cooler w/coldside pipeworkDeka InjectorsWalbro Fuel PumpThermostatNizpro Valve SpringsI'm getting my car tuned at the moment and this exhaust has been doing my head in. My original tune was set to be finished off Tuesday, but because the exhaust was flowing too well (believed to be due to the cat) it was suffering from sever boost creep. My tuner thought it appropriate that the wastegate mod be done.Its just been done and they're putting it all back together at the moment, but NOW the problem is the wastegate pipework on the CES dump. Its too small and doesn't quite open up the wastegate properly. My tuner was on the phone to CES just before and they said a few modifications around the face (ie: belmouthing it) could fix the problem. They're going to try that tomorrow, if it doesn't work... here are my options...1) Simply replace with a 4" dump2) CES also make a split dump pipe which has a 2" wastegate pipe instead of the 1.X" whatever it isOriginally I wanted to keep away from the turbulant 4"er, but at the moment I'm not too sure. Has anyone with the CES system had this problem before? Kinda disappointing as I've always thought highly of the CES system.Cheers,Jarrod. Edited 07/05/09 07:47 AM by Jman Link to comment Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 18y 10m 12d Gender: Male Location: Bentleigh, Vic, Australia Posted 08/05/09 12:05 AM Author Share Posted 08/05/09 12:05 AM The above post was not meant to flame CES by any means. Its a fantastic exhaust and am very impressed with the design. The problem could be caused by a) using a wastegate valve which is too large regardless of the dump pipe, orb) after speaking to Trevor at CES (who was very helpful mind you) its quite possible I may have a gayspec actuator which has too much throw in it Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 8m 1d Gender: Male Posted 08/05/09 01:29 AM Share Posted 08/05/09 01:29 AM can you change the wastegate spring without changing the flapper and enlarging the port? Link to comment Share on other sites More sharing options...
F6_jase Donating Members 322 Member For: 16y 4m 9d Gender: Male Location: Mooloolaba, QLD Posted 08/05/09 09:40 AM Share Posted 08/05/09 09:40 AM I'd be overboosting too with a sig like that! Link to comment Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 18y 10m 12d Gender: Male Location: Bentleigh, Vic, Australia Posted 09/05/09 02:35 AM Author Share Posted 09/05/09 02:35 AM can you change the wastegate spring without changing the flapper and enlarging the port?Sorry mate can't help you out there, not too sure.We've checked the actuator, that's fine so that's not the problem.The dump pipe is being sent back to CES to have the 2" wastegate section welded in. Haven't found much info on the 3.5/2" setup, what do people think of them??? Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 2m 25d Gender: Male Location: Melbourne Posted 09/05/09 02:39 AM Share Posted 09/05/09 02:39 AM Did you fit a bigger actuator Jarrod? Link to comment Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 18y 10m 12d Gender: Male Location: Bentleigh, Vic, Australia Posted 09/05/09 03:05 AM Author Share Posted 09/05/09 03:05 AM whoops forgot to add that to the list, yea a 12 pound actuator Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 2m 25d Gender: Male Location: Melbourne Posted 09/05/09 05:44 AM Share Posted 09/05/09 05:44 AM Why don't you like a 4" dump? Looks like it might be the only sensible option if they can't widen the mouth of that wastegate pipe...? Link to comment Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 18y 10m 12d Gender: Male Location: Bentleigh, Vic, Australia Posted 10/05/09 04:28 AM Author Share Posted 10/05/09 04:28 AM Yea it its gonna have to be.I prefer the setup of the split dumps. My car is a daily and one thing I didn't want to sacrifice is good response. The dump pipe will be sent off Monday, wish me luck. Link to comment Share on other sites More sharing options...
whistler6 Member 417 Member For: 17y 5m 26d Gender: Male Location: VIC Posted 11/05/09 03:07 AM Share Posted 11/05/09 03:07 AM How much do one of these CES exhaust cost?? Link to comment Share on other sites More sharing options...
