ratter Member 6,793 Member For: 18y 8m 17d Gender: Male Location: @ my laptop Posted 04/05/09 10:16 AM Share Posted 04/05/09 10:16 AM you wll need the actuator replaced to make 15-16 psi in the top end to get your power figures and with the gear you have listed if you add an actuator it will probably overboost so you may need to port your turbo, I'm sure Dave will explain all this to you. Link to comment Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 2m 5d Gender: Male Location: CQ Posted 04/05/09 10:18 AM Author Share Posted 04/05/09 10:18 AM you wll need the actuator replaced to make 15-16 psi in the top end to get your power figures and with the gear you have listed if you add an actuator it will probably overboost so you may need to port your turbo, I'm sure Dave will explain all this to you.Yea he has explained it all to me and we are going to see how it goes, and go from there. Link to comment Share on other sites More sharing options...
Ace blind leading the blind Member 3,657 Member For: 16y 5m 2d Gender: Male Location: Mt Alford, Queensland Posted 04/05/09 10:19 AM Share Posted 04/05/09 10:19 AM I reckon 300rwkw with out the turbo work 330 with Link to comment Share on other sites More sharing options...
The_Bogan Donating Members 881 Member For: 17y 10m 10d Gender: Male Location: Brisbane, Queensland Posted 04/05/09 10:29 AM Share Posted 04/05/09 10:29 AM I will guess between 295rwkw to 305rwkw. struggling to control/hold boost, with a hint of valve float. Link to comment Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 16y 9m 2d Gender: Male Location: Loitering in SEQ Posted 04/05/09 10:44 AM Share Posted 04/05/09 10:44 AM I agree. Get the actuator done & 315 - 325rwkw. Daves one of the best so he'll get the most out of & as safely as possible. Link to comment Share on other sites More sharing options...
jacob_xr6turbo Donating Members 433 Member For: 17y 5m 2d Location: Richmond, Melbourne Posted 04/05/09 10:53 AM Share Posted 04/05/09 10:53 AM The Bogan, valve float at 300rwkw in a BF? I thought they had better valve springs standard than BA's?actuator + port will give you 15-17psi, probably looking at 320-340rwkw..12-14psi without the porting or actuator, probably around 275 - 310rwkw..Good luck with it all! Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 7m 25d Gender: Male Location: Earth Posted 04/05/09 11:15 AM Share Posted 04/05/09 11:15 AM Seeing as you have the 6 speed auto, I'd be very interested to see, once it's been tuned, what power it makes in 3rd and then what it makes in 4th. Link to comment Share on other sites More sharing options...
XXRLNT TURBOCHARGED Member 372 Member For: 18y 9m 28d Gender: Male Location: MELBOURNE Posted 04/05/09 11:23 AM Share Posted 04/05/09 11:23 AM 315 rwk Link to comment Share on other sites More sharing options...
The_Bogan Donating Members 881 Member For: 17y 10m 10d Gender: Male Location: Brisbane, Queensland Posted 05/05/09 08:10 AM Share Posted 05/05/09 08:10 AM (edited) The Bogan, valve float at 300rwkw in a BF? I thought they had better valve springs standard than BA's?actuator + port will give you 15-17psi, probably looking at 320-340rwkw..12-14psi without the porting or actuator, probably around 275 - 310rwkw..Good luck with it all!yeh mate the BF's do have better springs but I dont know his car and how good his valve springs are...just because he has a bf doesnt mean his valve springs dont have to be replaced and wont suffer from float.have seen valve float numerous times of BF's. Edited 05/05/09 08:11 AM by The_Bogan Link to comment Share on other sites More sharing options...
DjGsTa Donating Members 944 Member For: 17y 10m 1d Gender: Male Posted 06/05/09 09:19 AM Share Posted 06/05/09 09:19 AM enoughtofryyourtyresrwkw Link to comment Share on other sites More sharing options...
