  • Member For: 21y 3m 20d
Sorry for the multiple posts but I can't edit any of my previous posts for some reason. The fuel pump at 6500rpm will need to flow 582lb/hr which means that the a1000 will be to small.
  On 03/05/2009 at 9:03 AM, straughsberry said:
At 86 psi, the Aeromotive A1000 will flow approximately 550lb/hr of fuel at 13.5 volts. Lets plug in those numbers: (550 / .9) / .6 = 1018.52
This formula should read (550*0.9)/0.6 = 825hp @86psi.
  • 3 weeks later...
  • Member For: 19y 3m 16d
  • Member For: 16y 3m 8d
injector flow app by efi hadware is very good try it and you will have your answer
MMMMM thanks for that ! It seems I need to go for something bigger for future needs
Can anybody tell me if these will be a direct fit for FG xr6 turbo? and what connector I should choose?
http://www.ebay.com.au/itm/SIEMENS-DEKA-80LB-835CC-FUEL-INJECTORS-EV1-EV6-USCAR-/230791220059#ht_1421wt_1399
Thanks all
Thanks Impellor
Saved me pushing the buy it now button !!
Any chance of some part numbers or links to fg xr6 turbo injectors ? Around the 80lb mark?
Thanks again
Cheers
Tom
Edited by tsammons
  • 10 months later...
  • Member For: 13y 6m 9d
It is an old thread but here is something from Ford racing on Injectors and pumps - worth a read IMO and really does back up the first post.
www.fordracingparts.com/download/.../ProperlySelectingEFIComp.pdf
