GMKILLER Donating Members 77 Member For: 15y 11m 16d Posted 15/12/10 06:29 AM Share Posted 15/12/10 06:29 AM just be carfull not to strip the nuts too... lol this means cuting the two bottom bolts off with a hacksaw and taking the manafold out.. lol fun fun.. also ford dont make a gasket for this I recon they should it would solve 50% of the problems... Link to comment https://www.fordxr6turbo.com/forum/topic/57319-getting-to-loose-bolts/page/2/#findComment-1063928 Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 4m 5d Posted 15/12/10 09:02 AM Share Posted 15/12/10 09:02 AM Wobble ended 3/8 extension and a 14mm short socket works a treat. I take it your talking bout the 14mm nuts that hold the turbo to the manifold so I think others are getting confused with 13mm bolts that hold turbo to housing. The back lower 14mm nut and stud usually end up sitting on the top of the engine mount when they fall out so have a look before you go buy one. Putting a gasket in there is better than having no gasket too. Link to comment https://www.fordxr6turbo.com/forum/topic/57319-getting-to-loose-bolts/page/2/#findComment-1063985 Share on other sites More sharing options...
John_K Donating Members 438 Member For: 16y 5m 30d Gender: Male Location: Sydney Posted 15/12/10 09:39 AM Share Posted 15/12/10 09:39 AM Yep I'm definitely talking about the 14mm turbo to manifold nuts.The front bottom one where you have to get to it from the rear is a real PITA!The other 3 were pretty simple to get to, but that front bottom one.. MAN!I've bought angled spanners, 3/8 uni joint, 1/4" uni joint and socket set, various square ended extension bars.HOPEFULLY these wobble bars will do the trick (yes I bought 1 in 1/4" drive and one in 3/8" drive to be sure). Link to comment https://www.fordxr6turbo.com/forum/topic/57319-getting-to-loose-bolts/page/2/#findComment-1064000 Share on other sites More sharing options...
spoolxr6 Member 312 Member For: 14y 6m 21d Posted 15/12/10 09:55 AM Share Posted 15/12/10 09:55 AM I also use a knuckle jointed extension bar with the socket and it gets it easy. Link to comment https://www.fordxr6turbo.com/forum/topic/57319-getting-to-loose-bolts/page/2/#findComment-1064007 Share on other sites More sharing options...
cobramad Member 824 Member For: 19y 10m 17d Gender: Male Location: Perth Posted 15/12/10 02:00 PM Share Posted 15/12/10 02:00 PM I believe Fraud stipulate retorquing the manifold bolts every 15k, and they allow approx 45mins to do so. One things for sure, they loosen heaps.. Link to comment https://www.fordxr6turbo.com/forum/topic/57319-getting-to-loose-bolts/page/2/#findComment-1064084 Share on other sites More sharing options...
GMKILLER Donating Members 77 Member For: 15y 11m 16d Posted 15/12/10 03:27 PM Share Posted 15/12/10 03:27 PM yea that front bottom one I found it verry easy to take the top front bolt rite out then take the 3 bolts that hold the actuator on then movie this out the way but still leave the rear rod connected... then get a 14mm rachet spaner in there and maby make a longer poll so you can get it tight... Link to comment https://www.fordxr6turbo.com/forum/topic/57319-getting-to-loose-bolts/page/2/#findComment-1064097 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 5m 20d Gender: Male Posted 19/12/10 01:14 AM Share Posted 19/12/10 01:14 AM just tightened all the bolts. I used two short 3/8" extensions and a uni joint on the end to get to that bastard bolt.I wanted to put the nissan lock tabs on, but could only get one onto the bottom rear nut (which was the only nut/stud which was about to disappear), oh well I guess every 10-15k will have to do. Link to comment https://www.fordxr6turbo.com/forum/topic/57319-getting-to-loose-bolts/page/2/#findComment-1064870 Share on other sites More sharing options...
DjGsTa Donating Members 944 Member For: 18y 1m 24d Gender: Male Posted 19/12/10 09:43 AM Share Posted 19/12/10 09:43 AM I always have the best solution when Im stuck in this situationtake it to your mechanic, let them do it. Link to comment https://www.fordxr6turbo.com/forum/topic/57319-getting-to-loose-bolts/page/2/#findComment-1064983 Share on other sites More sharing options...
Madwhip Member 73 Member For: 16y 7m 18d Posted 27/05/11 02:37 AM Share Posted 27/05/11 02:37 AM Does anyone out there make a replacement manifold that retains the factory dump pipe? I just snapped a stud in my manifold and I'm sick of m having an exhaust leek every other month. I want to fix this one last time. I have found Nord locks stopped the nuts working loose now the hole stud just drops out. Just to be clear I'm talking about the 4 studs that hold the turbo to the manifold. I spoke with Ford and they said they just fit what ever is lying around . I think that's how they designed the manifold. Oh look here is a NA manifold fit a flange on it and she will be sweet damn ford and there short cuts. Link to comment https://www.fordxr6turbo.com/forum/topic/57319-getting-to-loose-bolts/page/2/#findComment-1109407 Share on other sites More sharing options...
Jase86 New Member 11 Member For: 14y 8m 1d Gender: Male Location: G-Town Posted 02/07/11 12:10 PM Share Posted 02/07/11 12:10 PM I am having the same problem as we speak.. I argued with ford about the piss poor fact that 2 studs had fallen out and top 2 nuts were loose.. They fixed the problem.. and I argued over the cost and got the labour bill cut in half.. only months later (NOW) I can hear the leak again and know the nuts are loose.. Booked into ford to be re-tightened or whatever is needed on monday and I have told them I will not be paying for their work.. and if it comes loose again before the due service it will be being returned again.. Also I am after a manifold that will eliminate this problem.. if anyone knows please share your information! Link to comment https://www.fordxr6turbo.com/forum/topic/57319-getting-to-loose-bolts/page/2/#findComment-1119567 Share on other sites More sharing options...
