6psi > 3psi > 1psi... Whats Going On
w84me
  • Member For: 15y 10m 28d
hi all, I have a 2006 xr6t with a boost gauge fitted. last few days I have been loosing boost..
I first noticed on monday when I put my foot down and it only went to 3 psi, and I couldnt get it past it. so I kept driving it now it wont go over 1 psi...
I took all the pipes off to clean and check them.. took the bov off and checked it.. has this happend to anyone else? should I just take it into ford or....?
  • iTs alL DaRDy........
  • Member For: 17y 4m 26d
does it seam slower? not boosting? perhaps the gauge playing up. perhaps someone flogged your turbo I'd check that first
its going much slower...
it spools up but only goes to 1 psi.. cant feel the boost comming on.. I remember just before this happen it would go to 6psi and start to drop down.. wouldnt hold 6 psi through the revs... maby that has something to do
  • Member For: 17y 25d
if it were the turbo bolts you would notice it being louder. does it sound any diff? maybe the acuator is playing up if it wasnt holding 6 properly
Not always the case with the loose bolts, I had a boost leak that was caused by a few loose bolts and all that I could hear differently was a sort of ticking sound while spooling up. Sometimes with a few bolts it also sounds like a truck though
