Tuning Problem
stevet
  • Member For: 16y 9m 1d
Hey guys, sorted the problem with my XR6T not being able to run higher boost, it was a problem with the wastegate actuator being stuck open. New problem is with the engine temp. being higher than it was before which is causing detonation and limiting the amount of power it would otherwise be able to make. Reason for this seems to be my HDi Intercooler is substantially limiting airflow to the engine radiator causing engine temps to rise. I get the feeling I would have been best to leave the factory intercooler in place. Tuner is checking flow through the intercooler at the moment, but he tuned a stock falcon to a higher power level with no issues. So far hes been able to run around 9psi which was making about 225rwkw I think? I may be wrong there....Anyone had issues like this before?! Any ideas to over come this?
Cheers
Edited by stevet
  • Replies 37
  • Mmmmm......BOOST
  • Member For: 17y 8m 16d
DONT LIKE BAGGIN PEOPLE OUT , BUT DOES THIS GUY REALLY KNOW WHAT HE'S DOING
if he's doin dyno runs on the car he shouldn't be letting it get that hot any way has he tried lowering the temp at wich your thermo fans come on , and if he thinks the airflow is a problem he may need a bigger fan set up in front of the car , some of the coolers these cars run cover the whole of the radiator without overheating issue's
and the thermostate may not be stuffed as in being an issue , but running the lower temp is common practice with these cars
Edited by our06t
Cheers our06t, what your saying made sense to me. Will talk with him about it later, I think it would be fair to say he probably wouldnt be on the same level as tuners you have over there. And may not have the benefit of working on as many xr6t's.
  • Mmmmm......BOOST
fair enough just make sure he goes bit by bit then and doesn't kill anything on you
maybe send people like , headsex , blueboost and Ratter if you get real stuck all these guys know their stuff and aren't to precious about giving away the stuff they have learn't
Edited by our06t
yeah good idea. if anyone else could provide any other solutions it would be greatly appreciated. Its hard to find people knowledgeable about XR6T's over here in NZ! Seems like the answer to almost anything Ford lies amongst these forums!
Cheers
  • Member For: 17y 4m 26d
If what you say is true, it sounds like your tuner is a bit lost. And if that is the case, then do yourself a favour and get a second opinion. In other words, you might consider trying a different tuner.
yeah that is easier said than done, would have to travel quite a distance to go elsewhere and may encounter similar problems. And I am going off the fact that he tuned a stock XR6T to 330rwhp which is fairly decent. But I also realise there is more to a tune than peak power. I have heard of tuners in Auckland who are quite skilled wih falcons but im at the other end of the country!
  • Member For: 17y 7m 30d
I have had no issues with engine temp or tuning with this intercooler. Maybe the airflow is just too low on the dyno. Too much heatsoak? I find the piping in the engine bay to get quite hot, although the intercooler has always been ok, warm on the inlet side of the cooler but mostly cold the rest of the cooler. I have also removed the stone tray under the cooler and have had no issues on the freeway either. I made a conservative 236rwkw on LPG, everything else standard.
Edited by Pube
