Tuning Problem
stevet
  • Member For: 16y 9m 16d
yeah fair call bfhoon. only issue is we had an agreed price to tune the car. when I picked the car up, I payed for it, even though the result wasnt what I had anticipated. he had still done all the things that went with tuning the car. he said if I sort the problem he'll finish the tune so it makes some good gains. but if I want him to find the problem ill have to pay for it......guess I'll have to take it back and get him to find the problem and reach some sort of compromise.......
  • Replies 37
Thanks ratter, yeah the solenoid hoses are fine. Car is back in today to check the actuator, apparently it is tricky to check it is working short of taking it off. my moneys on the actuator, but its really a process of elimination.
  • Member For: 17y 9m 24d
could be valve springs not allowing him to run anymore boost or the fact that your exhaust is standard.
its not that uncommon for early model ba's to make crap power on standard valve springs and exhaust.
Tuner called to say their is a problem with the actuator, so it'll come off next week to get repaired. Also noted the one of the turbo bolts was very loose and that the turbo bearings were a little noisy, so I guess the turbo will come apart for new bearings. Anything I may as well do whilst everything is in pieces?? Car has only 65 Km on the clock, things can happen at anytime huh!
Edited by stevet
  • Member For: 18y 8m
If it was a exhaust housing bolt that was loose, you may find that the housing has a crack into the thread hole, if this is the case it will continue to come loose.
Yeah I'll look into that. Dont think I'll bother too much with the turbo, dosent sound like its that bad and the cost to replace bearings is apparently quite high. I better gap the plugs this weekend for when the tune gets loaded, what should I set them at??. Hopefully will be able to run 12psi once actuator is sorted then I'll leave it at that for this car. fingers crossed the valve springs and injectors can handle it.
Buy a set of pre gapped plugs to .8mm and you should not have a problem with them, boost will need to be pulled down in the top end as injectors will be maxed out at approx 4500 rpm with 12 psi
yeah I'd like to do both those things. Is porting and fitting a larger flapper it a straight foward process most tuners can carry out or will it possibly need to be done by a specialist. My understanding is this will allow the boost to be more stable and better controled. Correct? Hopefully can get 250rwkw..........
