  • 9 months later...
  • 2 months later...
  • 570Nm @1800rpm
  • Member For: 21y 7m 10d
Nice work! Wish I didn't have the standard BA flat lid so I could do this properly.
It can still be done. I'll put up some info once I finish (start) mine.
  • 7 months later...
  • Member For: 14y 3m 1d
saw the sweetest light set up 2 weeks ago couldnt take pic. The guy set up LED lights on the underside of the Tie down aluminium bars along the side. It was set up with white and Red lights switchable. All the bits he got from supercheap autos and made up. trev
  • 1 month later...
  • Inactive Members
  • Member For: 14y 1m 17d
hey guys new on here im an auto sparky and if you arent keen on drilling holes in your lid you can pick up led strip lighting by the roll 60cm is more than enough and light enough so you can mount them with velcro to your lid im about to install them in mine I know this works and holds because I have installed them in my brothers troop carrier the light is more than sufficient im goin to use deutsch plugs on them so the lid can still be removed if needs be
  • 2 years later...
  • Member For: 12y 3m 13d
I've done this on my FG, I used LED Autolamps from Autobarn and wired them in to a reed switch so when the hardtop lifts up, the 4 lights come on. When you close it the lights go off.
Add a switch to the ground side of the circuit and you have the ability to turn them off.
Going by the photo's its about twice as bright as posted above. (but that's all in the continual improvement of SMD LED technology)
  • 8 months later...
