H4 Halogen Head Light Bulbs
Doguepound
  • Member For: 18y 5m 21d
Right... I'm a total novice when it comes to bulbs so I need some help.
I need to replace main high/low beam bulb, and I've been told that the BA's use the folllowing bulb for this: 55/60 watt H4.
I've got a pair of H4 Halogen bulbs that are rated as 100/90 watt and I'm wondering are these ok to use?
can someone explain how these differ from 55/60 watt?
does it refer to power required, or light emmitted?
like I say guys... I'm a novice with these so any info would be appreciated.
thanks
  • blind leading the blind
  • Member For: 16y 4m 16d
the 100/90 is the wattage of hi to low so they will be a whole lot brighter than the standard bulbs - oncoming motorists will hate you I went with the 50% brighter bulbs ya can buy (still 55/60) and I get flashed all the time
  • Moar Powar Babeh
  • Member For: 19y 4m 4d
90/100's will melt you wiring and reflectors in you headlights. You would need to install a relay for hi, a relay for low and possibly a change over relay. you would need to tak a fused power feed from the battery to supply the globes,
FYI 55/60's on high will draw aprox 19amps 90/100's will draw aprox 31amps. A substancail increase.....
  • Member For: 20y 11m 13d
My brother had an engine bay fire from the 90/130 globes in his mazda 323.
The wires melted and shorted out causing the airbox to catch fire.
Just replace the stock globes with the Phillips +50%, as they are a much better globe.
